Dick Sarre
New Member
- Joined
- Mar 25, 2021
- Posts
- Reaction score
- Location
- France
Hello
When trimming surfaces in Maxsurf Modeler (for example a skeg keel to a hull) two intersection edge lines are created, one for the hull and one for the skeg keel. The section lines of the hull/skeg keel at the intersection either overlap or are discontinuous. This is only visible when zooming right in to the trimmed intersection and the overlaps or 'open' sections are only in the order of a few mm. When looking at the sectional area curve, all is OK with no discontinuities. Is this normal? If not, what might be causing the problem? All surface penetrations are good and surfaces trim correctly, with the exception of the very small overlaps/discontinuities.
I need to use the model in Hydromax for stability calculations, so want to be sure that the model will be analysed correctly.
Thanks in advance for any assistance/clarification that anybody can offer.
