Trimaran motorboat / stabilized monohull
Discussion in 'Boat Design' started by Eric DEBORDE, Oct 12, 2009.
  1. Eric DEBORDE
    Likes: 33, Points: 28, Legacy Rep: 160
    Eric DEBORDE Junior Member
    Some pics of my 10m proto and drawing of the futur 12m.
    On the proto :
    The center hull is 80 cm wide, the amas are 20 cm wide.
    The hull is 500kg in plywood/fiberglass.
    The 60hp outboard make her going 22 knots woot / 17/18 cruise.
    Does somebody made something similar to share numbers with me ?
    Sorry for my bad English, I am a french frog! :p
  2. Ad Hoc
    Likes: 1,971, Points: 113, Legacy Rep: 2488
    Very jealous of your beach!!!
    How much does she weight?
  3. marshmat
    marshmat Senior Member
    Hi Eric, welcome aboard :)
    Quite a stylish thing, ain't she? (And I, too, am jealous of your beach ;) )
    Rick Willoughby (member on here) has been tossing around some variations of a "faux-tri" concept with some similarities to your hull. And on the larger side, one of the U.S. Navy's new Littoral Combat Ships also uses a similar tri-hull configuration.
  4. Tcubed
    Likes: 18, Points: 0, Legacy Rep: 318
    Tcubed Boat Designer
    Pas mal. C'est en bois?
  5. Fanie
    Fanie Fanie
    Interesting design ! If you have more pictures it would be nice to see more of it.
    The rest of you should note that Eric is a very clever person - note the fishing rods on his boat :D
  6. Eric DEBORDE
  7. HJS
    Likes: 139, Points: 43, Legacy Rep: 288
    HJS Member
    Figures?
    10 m wl, 22 knots with 60 hp?
    Can't be correct!
    What total weight?
    What prop?
    js
    www.sassdesign.net
  8. marshmat
    Eric's hull dimensions and general below-water shapes are pretty close to those of a tri I'm working on now, although his is 2 m longer on the main hull waterline. If his bare hull is 500 kg, I would expect maybe a hair over a tonne (say 1000-1200 kg) with motor, equipment, fuel and a couple of people. (Eric- can you confirm your actual weights?) From my own calculations, 20 knots or so for a tri this size on 60 hp is not at all unreasonable.
  9. Eric DEBORDE
    Weight empty / no motor 500kg
    60hp 2 stroke yamaha 102kg
    Varta 55Amp 15kg ?
    fuel 100 kg
    hydrolic pump cylender and auto pilot 10/12kg
    aluminium anchor and chain 15kg
    extras 100kg
    TOTAL : 850kg empty
    22 knots wot is with 2 frogs 70kg and fishing gears for a total of aprox 1000kg
    Cruising at 4000 rpm with 17"pitch prop give 17/18 knots depend on waves.
    Cruising at 4000 rpm with 7 people and camping gear for a total of aprox 1600kg give 15/16 knots
    I should try a 15" prop but can't find one !
  10. Ad Hoc
    That puts it around 60hp/tonne
    Looking at my chart of old boats and sea trial data, that gives around Tq of roughly 4....this equates to 22 knots...so yes, stacks up.
    With 7 froggies....(and their cheese, wine and bread too?? :) )...roughly 17~18knots..so again, not bad, stacks up with other trials data of this "type" and "size".
  11. Nordic Cat
    Likes: 8, Points: 0, Legacy Rep: 72
    Nordic Cat Senior Member
    Great looks, and I bet she's a nice dry ride in waves.
    Alan
  12. Willallison
    Willallison Senior Member
    Fantastic Eric!
    I too would be jealous of your beach...if I didn't have access to similar ones myself;)
    The boat is somewhat reminiscent of "White Rabbit" a superyacht built here in Tassie... if on a slightly more...err... practical scale:D
    Please - more pics - particularly of the interior - I'm interested to see just how much space you managed to fit into (onto) such a narrow hullform.
    There are a number of people (myself included) who are working on variations to the stabilised mono theme. Your's is a fine example - congratulations!
  13. mwatts
    Likes: 1, Points: 0, Legacy Rep: 28
    mwatts Martin
    Hi Eric,
    Nice looking boat. I was wondering about forward visibility though. How are you ensuring that?
    I am currently designing a trimaran myself. A lot smaller than yours.
    LOA: 5.90 m
    Beam: 1.95 m
    Draft: 0.40 m
    Power: 15 - 20 HP
    She'll be heavy though (about 1000 Kgs fully loaded), because I am designing her to be built from steel. I expect to get about 10 Kn @WOT with a 15 HP.
  14. Manie B
    Likes: 123, Points: 63, Legacy Rep: 1818
    Manie B Senior Member
    Eric i have just looked at your website and cannot find any pics of your boat on the water other than the 2 photoshop pics of the boat on the "beach" am i missing something?
    Your build pics are great - and if you were able to go from wooden hulls (April 2009 entries) to the water in 6 months you did remarkably well
    Your design concept is very interesting but it would be nice to see pics or video of the "tri" underway :?:
  15. Eric DEBORDE
    Thank's all !!
    Martin, I think that lightweight is the key for economie ! "tri hull" structural shapes are easy to make very strong, much stronger than a clasic monohull. Make a balsa model of your boat and try to twist it !! You will see how strong it is ! I wouldn't go for steel.
    Manie, I will try to catch pics and video of the "tri" underway.
