First time poster here. I am hoping to get some input on a possible trim tab upgrade I would like to do on my 2012 Parker 2520XLD.
First some history, I have spent a lot of time fishing on an older model 2520 Parker similar to mine before buying mine two years ago. Although I believe the hulls below the water lines have not changed, my boat is considerably different from the old model. For those not familiar with the 2520 XLD it is a 25 x 9-6 20 degree deep V hull. Although real world numbers are hard to find, the best guess is the new model is a minimum 1500 lbs heavier. Or about 8000 vs 6500 lbs. Add to that, IMO, the balance is bad due to the 300 HP Yamaha outboard that is 4+ feet off the stern on a bracket and a larger fuel tank in the the original position used with I/O models. (To far aft now, IMO) The rest of the increased weight is in more F/G and lots of HDPE (Bigger cabin, more free board and HDPE in place of F/G hatches ect.)
My boat is pretty much stripped down with all easily movable weight forward now. The new models like mine are much faster and the additional weight is O.K. at those higher speeds, but has killed the low speed performance needed here on the lumpy west coast.
I have proped way down with a stern lifting four blade prop which is a good change but IMO a band aid at best. The stock Lenco tabs I have are an odd configuration IMO. No idea why, but they are 12"w x 20" long (12" hinge on transom). As mounted they retract about 5 degrees above the hull as I think they should. After 2 years I have found the boat runs best with at least 5 degrees down tabs (beyond parallel with hull) at all times. The boat just feels extra stern heavy at any speed under 28 mph. Full motor in trim and full 12 degrees down tabs are need to stay on plane at less than 24 mph. Although full in trim helps to raise the stern it really lowers the bow and plows.
So....Because i can't really change the balance or the gross weight I am considering installing large tabs to effectively lengthen the hull and raise the stern especially at low speeds. As of now I am looking at the Lenco 30w x 12 long or the 24w x 12 long.
My questions and concerns are as follows:
1) When are the tabs to big?
2) Could the drag from the over size tabs defeat the purpose even in a position of parallel with the hull?
3) will I induce ventilation issues? With the 30" wide tabs I will have 36" gap between the tabs and the single prop on center 4' behind the trailing edge of the tabs.
4) Is the boat just a pig and won't be fixed?
5) What are all the other things I have not considered?
The job to replace is some what costly and involved as I must reposition the rams. So I will take all input seriously. I have done searches and lots of informative reading here on similar subjects and look forward to hearing from the experts. Any other ideas, thoughts or concerns welcome.
Thanks in advance.
Thanks in advance.
