Hello all!
I have previously worked with Tribon initial Designs before it was bought over by AVEVA.
Back then, they had a Form module inside the package which allows you to generate a hullform using either an offset data(imported hullform) or user input parameters(user inputs key particulars about ship and fairing needs to be done to achieve smooth hullform)
However, now the AVEVA initial designs have lines, surface and compartments and hydrostatic & hydrodynamics module. Missing the module of Form that was previously available.
I was wondering if there is the function of user input parameters still available in AVEVA where you can key in important particulars and the software will generate a rough hullform so that lines modellinig and fairing has to be done.
Thank you.
Thank you.
