Transverse frame calculation
Discussion in 'Class Societies' started by DUCRUY Jacques, Apr 30, 2012.
  1. DUCRUY Jacques
    DUCRUY Jacques Junior Member
    Hello,
    Can I submit you an example of calculation for a transverse frame for a sailboat with ISO 12215-5 ?
    The boat had a Lwl of 9 m and a displacement of 6500 Kg, built in steel. The frame space is 0.60 m : I assume (see sketch under) that l = 2.20 m, c > 0.18 l and that the point "P" is under the waterline.
    I take the minimum bottom pressure (0.35 Disp^0.33 + 1.4 Lwl = 19.13 kN/m². The allowable stress is : 235 * 0.8 = 188 N/mm². The curvature factor is 0.5 (as c > 0.18 l).
    SM = ((83.33 * 0.6 * 2.2² * 19.13)/188) * 0.5 = 12.35 cm^3
    Is my reasoning correct ?
    Thank you in advance
    Best Regards
    Jacques
  2. TANSL
    Likes: 886, Points: 123, Legacy Rep: 300
    That is what I get with my program SCT.
    Best Regards
    Ignacio López
  3. DUCRUY Jacques
    Hello Ignacio,
    Thank you very much for your answer.
    In fact, in my question, I had supposed that the crown stiffener is 18 % of the unsupported length, so the Kcs is 0.5. If I correct your figure for frame SM (19.96 * (0.5/0.827), we are agree.
    But how do you calculate the base bottom pressure of 31.8 kN/m² ?
    Best Regards
    Jacques
  4. TANSL
    Yu are right, Jacques.
    See new file "Ducruy-1.doc", in previous post.
    B.R
  5. DUCRUY Jacques
    Thank you very much
    BR
    Jacques
  6. heart91
    heart91 New Member
    I am new to design.
    How can i learn to read rule Llyod's for what is meaning between 2,5H and 7,5H????
    Can somebody help me.
