Hi, I have a aluminum 1979, AMF Crestline '19 Norseman with MerCruiser 140 with a Mr (pre Alpha 1) drive and need to replace the plywood transom. The existing plywood is 1" spanning the entire transom with a smaller 3/4" piece (total plywood transom thickness 1 3/4"). There is no epoxy or fiberglass adding to the thickness. My marine mechanic believes the transom should be 2" thick. Given the boat is 42 years old, it's unlikely the plywood I'm replacing is original so it's anyone's guess what was originally spec'd for the boat. Prior to my mechanic's feedback, I purchased Coosa board (instead of plywood) to match the plywood thickness. My question is, is 1 3/4" thickness of Coosa sufficient for this application? Any help is deeply appreciated.
