transom repair
Discussion in 'Fiberglass and Composite Boat Building' started by andrew, Nov 1, 2004.
  1. andrew
    andrew New Member
    Hello all,
    I have a 1989 17' Nissan fiberglass boat "V" hull with a 90 HP Nissan motor on the back. My transom is soft and i need to repair it. I have been talking to some mechanics and they said it cost about a thousand dollars to repair. I can do it myself for about 3 or 4 hundred dollars. I need some basic help on transoms: like the width of it, what sort of brackets could i use to bracket it to the supports that run the length of the boat. Should i use sheet metal or marine plywood. I also had a suggestion to put two 3/4" of marine board and 1 sheet of aluminum in the middle then fiberglass the whole thing. If anyone has any suggegstions or has done this to a boat before i would really appreciat the help.
    thank you,
    Andrew
  2. Dutch Peter
    Likes: 7, Points: 28, Legacy Rep: 66
    Dutch Peter Senior Member
    Repair it as it was original. That way you don't have to rethink the whole structure and you'll be done with it for the next 15 years.
  3. rookie repair m
    rookie repair m New Member
    I repaired my transom and replaced it only with plywood. try www.transomrepair.com thats some quick deal but search for the book "how to repair fiberglass boat transoms"
  4. D'ARTOIS
    Likes: 18, Points: 0, Legacy Rep: 321
    D'ARTOIS Senior Member
  5. HWL
    HWL Junior Member
    I have replaced a few transoms like you have , and have had good success with using plywood layers totally encassed with fiberglass built to the original thickness and pattern
  1. Andrew Courtney
  2. E350
  3. GP1998
  4. davels1
  5. reelboater
  6. Canracer
  7. rovi
  8. Flying Flivver
  9. Schoonner
  10. nikous
