Note: This feature may not be available in some browsers.
The seam is not tabbed properly. To tab it well, I’d recommend 4-5 layers of 1708. Each layer is about 2cm shorter, and the longest piece is first with a 5cm minimum on each side the sole and transom skin. For five pieces; the last piece is 10cm and the prior would be 15, and the prior 20 and for 4 layers, 25cm wide across the entire sole/skin.
Then your plywood can be hogged out a bit for the extra glass, and then the plywood also gets tabbed same way, like 3 layers. I’d not allow the deficit under the new transom plywood.
If you decide the epoxy is enough, then tabbing the transom to the sole might be sufficient, but the crack is pretty bad and needs to he addressed before you make it inaccessible.
Thank you again! The crack is constrained to where the green polygon is, and is apparent only from the exterior side where the tubes attach. There is no crack in the connection of the transom skin to the deck/sole of the boat. Only what I grinded down. The ply was coming very low to the deck before I grind down, this is what it looked at a previous stage of the rebuild. I had to clean the rotten ply where the green arrows are. The ply was stopping approximately around the red circle and there was only fibreglass (or fibreglass and thickened epoxy, as it has weird shape in some parts) around the drain hole. The ply was more rotten to the port side (where the crack is) and I assume this is because the crack was allowing water to get in from that side. The crack is basically on the exterior of the hull where the tube is attached, i haven't seen it anywhere in the interior.You did not answer my query.
Does the crack extend further than the edge and toward midships?
Grind a taper into the crack. The crack thickness to zero. I’d go about an inch or whatever you can. For 3mm, 3 pieces of 1708. Place them into epoxy putty made with cabosil, then each piece is bigger.
Then, if you have access to the other side; add some more glass.
Then, once you add the plywood, tab it to the sole, biggest pieces first.
Plywood needs to be precoated with epoxy to prevent it from sucking resin from fillers.
I prefer to use 1/16” to 2mm vee trowel on both sides of the bond for flat surfaces. You need a way to get the plywood tight. Usually, the best way is to make some bolt holes and repair them.
Correct. But fix the crack first. Just no reason to tab the skin. I was confused about the extent of the crack.Thank you, just to verify: it is my understanding that since the crack does not extend to the connection of transom skin with deck, you do not suggest to tab there BEFORE inserting the plywood, correct? Many thanks
View attachment 195630 View attachment 195629 PIt should be noted those cracks were caused by stress and some structural deficiency.
When you repair the transom; if possible, best practice would be to radius the top edges and overlap the fiberglass from the inside over the outside and in. This is, of course, tricky at the inside corners. What is normally done is avoiding sharp corners or adding them back at the end. So those sharp inside bend are rounded with putty as well as is the back top of transom. So you first add putty to the top inside corner, then you radius it to allow glass to roll over. If at the end, you want a square transom; it is done with fairing fillers. If my remarks are not clear; let me know.
Not sure if these pics show a round transom top edge or not, but this has a 3/8” radius on each side of a 1.5” transom.. and this has 8 layers of db1700..
If you don’t glass the top of a ply transom; it WILL split open. This one is a hd foam core..View attachment 195631 View attachment 195632
