Sunfish Conversion?
Discussion in 'Boat Design' started by Rowdy, Apr 19, 2004.
  1. Rowdy
    Rowdy New Member
    Hey all this is a great looking forum. I got a few questions about a project i am about to take on..
    I am a waterfowler and i just aquired an older alcort sunfish sailboat hull only. my plan is to convert it into a barnegat bay sneakbox. i know this conversion has been done before but i can not find any info on the subject. also for power i was thinking of gutting and transplanting the innards of this old jet ski that i have (thats right jet powered sunfish) i wasnt sure if this should have been posted in the sailboat forum or this one. but if anyone has any ideas for a sailboat conversion i am open to all suggestions.. thanks in advance.
  2. SailDesign
    Likes: 197, Points: 73, Legacy Rep: 650
    Rowdy (by name as well as by nature?),
    I would advise against the jet-ski conversion unless you want to scare the ducks to death. Not sporting.
    Instead, why not a nice short-shaft trolling motor, with a big battery? That should push you along nicely, and be cheaper to run as well.
    The thing is, the Sunfish hull is just plain the wrong shape to take a powerful jet well. Too much rocker means that the only way to keep the intake "planted" will be to run at an angle of 10-15 degrees or so. A good recipe for flying lessons at speed in that thing :)
    You might also consider the traditional solution - a large sculling oar over the stern. Lie back in the boat (well, as much as you can in a sunfish) and have the sculling oar over your shoulder.
    That said, if you are sold on the jet drive, have fun but don't say you weren't warned...
    Steve
  3. Gene Rosson
    Gene Rosson New Member
    Rowdy; Do yourself a favor by forgetting the jetski/Sunfish idea. I know the Sunfish well , having sailed them extensively. Sometimes over rigged with a Hobie 14 sail and other absurdities. It would make a decent waterfoul boat but it will accept,maybe, two horsepower and you wont use both of them. Take the other guys advice and use a small electric motor with a big battery. Good luck = low power. Regards
    Sandspur
  4. 9609
    9609 Junior Member
    Trolling Motor
    I agree with the idia of puting in a trolling moter. You may be able to mount it on the existing rudder brackets. Also, on the deck consider puting flexable solor panals to charge the baterys. Maybe even keep a smaller sail to asist the motor for longer trips. Just don't put a 100hp jet drive in. Hope it comes out well. :)
