Transferring pressures and motions from aqwa to ansys APDL
Joined
Oct 30, 2017
Messages
3
Reaction score
Location
Brazil
good evening everyone,
I need help in transferring pressures and motions from aqwa to APDL. I was able to convert the ANALYSIS.HYD (that is generated after aqwa simmulation) file to .AHD which is used by the OCREAD command to apply the pressure field in the structure. however, when I use the OCREAD command, ansys issues the following message: "number of mass data is different from the expected value". Does anyone know how to solve this problem?
Back
