Hi All,
I've been thinking about a boat-building project but don't have the inclination to start from scratch. My desired vessel would trailerable, be used mainly in sheltered waters with the occasional coastal trip thrown in. As a sailor I'm quite happy traveling at displacement speed. I have a 25hp Kubota diesel and most of the running gear to set it up. I'm thinking a trailer-sailer might be a suitable "donor" for conversion. I'm comfortable with undertaking the work involved subject to getting some guidance about modifications to the keel and rudder design.
I have a hull in mind that may do the job. It's a Hood 23 which is quite a common boat in Australia (not sure about elsewhere?). Solidly built and cheap to buy. I think the hull is quite attractive in a retro kind of way and I would build a cabin on the standard flush deck design. They were made with fixed keels and also as trailer boats with a swing keel. I've attached a photo of one.
I have some questions about my proposed project....
Would 25hp diesel be overkill in a boat this size? I realise I'll be limited to hull speed which is maybe 6 or 7 knots. Motor and trans weighs in around 130kg. I love the little Kubotas. They're bulletproof and run on the smell of an oily rag (approx 2 litres per hour).
Not sure about centreboard weight but I'm thinking this would be removed or at least reduced in size to offset the motor weight. I would like to incorporate a steadying sail so some weight down low would be good.
In terms of motor installation, I would build up a small keel around the shaft tube. The hood does have a small keel along its length but I'm thinking the boat would track better under power with a bit more of a keel profile especially at the aft end. Am I on the right track with the modified keel concept?
As for rudder design I'm not sure. The standard boat has a transom mounted tiller rudder. I would want wheel steering (mounted on bulkhead) so I'm assuming traditional rudder setup would be located at the end of the keel for protection and steerage. How do I determine rudder size relative to prop? I believe a 13 or 14 inch prop would be about right . Gearbox has a 2:1 reduction and converted boat would weigh about 1300kg.
So...quite a few questions posed. I would appreciate constructive feedback regarding my concept. However, if you think I'm completely misguided please say so ....and why.
