Trailable house boat
Discussion in 'Sailboats' started by Quidnic, Sep 16, 2021.
  1. Quidnic
    Likes: 13, Points: 8
    Quidnic Junior Member
    What are the best designs for something we could use as a caravan but also launch and sail sometimes?
  2. fallguy
    Likes: 2,045, Points: 123, Legacy Rep: 10
    Need more details about sizes; destinations, etc.
  3. bajansailor
    Likes: 1,881, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
    As Fallguy mentions above, please elaborate a bit more as to your current thoughts behind this house boat.
    How many people will it have to accommodate, and for how long at a time?
    What will your typical cruising areas be like - eg very calm lakes or rivers, and / or coastal areas as well?
    What is the maximum speed desired?
    You mention 'launch and sail' - are you looking for a houseboat that has the capability of actually sailing, or just motoring?
    I presume you mean a sailing houseboat (as this thread is in the Sailboats forum) but I just wanted to confirm.
    If so, how 'good' does it have to be at sailing? Will she have to sail to windward effectively, or maybe just on a beam or broad reach occasionally, with anything closer to the wind being done with the 'iron topsail'?
    Are you intending to build the boat yourself?
    If so, what would be your preferred hull material (eg plywood, foam sandwich, aluminium.........)?
