...tpc / Tpi...
Discussion in 'Stability' started by fradrigo, Oct 22, 2007.
  1. fradrigo
    fradrigo Junior Member
    Hi all, I need a little help in deriving ratio between metric and imperial unit immersions ( Tonsmetricpercentimeter / Longtonsperinch ) Obviously we need less mass to immerse a boat one centimeter then one inch ( 1 longTon correspond to 1.016 metricTon ), but whatever trick I pull from the bag I keep geting larger than one ratio ( 2.5 to be precise ) What am I doing wrong :confused:
  2. Guillermo
    Likes: 189, Points: 63, Legacy Rep: 2247
    Guillermo Ingeniero Naval
    1 lt/inch = 1.016/2.54 mt/cm = 0.4 mt/cm
    1 mt/cm = 2.5 lt/inch
  3. fradrigo
    Thanks Guillermo, I'm geting the same result...but the common sense tells me that TPC should be less then TPI ( ratio TPC / TPI less than one ) ?
  4. Guillermo
    ....TPC should be less then TPI....
    And they are!
    0.4 < 1
  5. fradrigo
    ...1 lt/inch = 1.016/2.54 mt/cm = 0.4 mt/cm
    1 mt/cm = 2.5 lt/inch...
    mt/cm = TPC
    lt/inch = TPI
    according to your second line:
    TPC = 2.5 TPI
    TPC / TPI =2.5 > 1
    ...still confused :)
  6. fradrigo
    ...I've checked in one of Hydromax's sample models ( varying units for same waterplane area ) and got :
    TPC = 1.097 tm/cm
    TPI = 2.743 lt / inch
    So TPC/TPI = 0.4 ,
    Inverse what we derived for the same ratio ( 2.5 )...I'm not very good in dimension analysis..Anyone out there ??? :)
  7. Guillermo
    :rolleyes:
    1 mt/cm = 2,5 lt/inch
    (1/2,5) mt/cm = 1 lt/inch
    0,4 mt/cm = 1 lt/inch
    This implies you need less weight to sink a boat 1 cm than to sink it 1 inch (as is evident).
    An example:
    If you take a parallelpipedic hull, of 1 sqm section, floating in fresh water (density = 1), you need 10 kg to sink it 1 cm but you need 25,4 kg kg to sink it 1 inch.
    Check: 10 kg = (25,4*0,4)/1,016
    What's the doubt....:confused:
  8. fradrigo
    :idea: It's clear now, thanks ! :)
    ' ...open mind for a different view... '
  9. Guillermo
    Veritas lucet omnibus....:)
  10. fradrigo
    Tempus omnia revelat ;)
