Good Morning Boat Designers
Old Business from Lucus
1. Your boat doesn't have moveable ballast
The movement is on and off the vessel. Boats that have side to side ballast probably were built that way owing to design rules that limit the total amount of water ballast that can be carried.
2. You can't be bloody serious about what you write.
Very serious. I do not post what I do not believe
3. TransPac 52's are not Santa Cruz 52's.
The history of the TP52 could be extended all the way back to Gimcrack. They are joke boats owned by fools if owners really think TP means TransPacific. That is my opinion, but it is confirmed by the math. SNAME calculations back me on that. They are not TransPacific worthy (at least not the early versions). They could be good TransPortable buoy racers.
Perry has given us a lot of to analize. Lets do so. If the SC52s are not TP52s then why is Lee always mentioned? Sadly Lee designed neither boat. Farr is responsible for both. A designer from Farr teamed with Lee to build the first SC52. That monkey business continued with the TP52s until just recently. Perhaps it continues today. I like to think Lee not involved any more.
4. I don't know what you have against people who desire a class of boats with owner/driver rules, box design rules, and have the money to afford 2M USD. You don't have that kind of money and you don't know what it is like to run in those circles.
Oh, you didn't run a credit report on me. Others have. As of today, in the US, the folks asking for credit reports must be reported. Just don't go there. It is rude.
FYI, I think a TP52 is significantly less expensive than 2 million. Of course after the GP RWP rejected Teeter Principles, the boats lost half of their resale value over night.
This is what I have against design rules. They often produce foolish designs.
The TP52s are PHRF boats, as far as I am concerned. PHRF attempts to hide the mechanism for rating from designers so that the mechanism can not be gamed. That mechanism is currently in the form of software code. Unfortunately the red hand of Teeters is all over it. Rather than using a neural network, which can not tell you how a result is obtained, and hence is the perfect mechanism for a PHRF rating tool, Teeters apparently had a tool coded up based on his own personal huristics. This means movable ballasted boats are disadvantaged under the tool because Teeters rules of thumb exclude them from ever being racable. That is the theory those of us investigating the rating tool are operating under. Good question BTW, as is the owner driver one. Read up on neural nets. These are used in aircraft to keep them flying smooth. The same is being applied to sailboats, I suspect. Oracle isn't into this sport for nothing.
BTW, it would be a relatively streight forward undergraduate project to take the PHRF data, boat specs, and race outcomes and apply it to rating future designs using the same technology. Why this hasn't been done yet is the question. Typically the objection is that the results are not auditable. You can not say how the rating was determined. But that is what is wanted for a rating mechanism that can not be used by designers to create foolish boats.
My problem with owner driver rules is that it keeps boats like Braveheart (a TP52) from competing. In PHRF, if the owner is not available for a race, the boat is still raced. That means the boats experience while racing can be used to show if the vessel is fast or slow. The owner of Braveheart did not want a TP52. His designer did and thought that value would be preserved if the PHRF buoy racer was designed to the TP52 rules (which keep changing BTW).
There is another problem that bothers me and it involves course design. To make a fixed fin vessel appear fast, in comparison to faster designs, courses are prepared for them. We call those courses Windward Leeward courses.
The slowest point of sail for any boat is directly down wind. Up wind is also slow going. Hence slow designs - like TP52s possibly - appear to do well on WinLee buoy race courses. But they may not really be fast.
5. Not sure why you can't comprehend plain facts unless you are learning disabled.
These are plain facts that have been in dispute since the 1920s and Blue Bird, the first twin keel boat. But they are not considered appropriate for discussion among the trophy kids who are expected to sail like their daddies. Which is foolishly.
A blue bird tells us that twin keels become more effective with increased angle of heel, while a single keel becomes less effective. Twin keels also reshape the wave pattern to produce a flatter wake and can reduce the effort needed to break out from hull speed. Windward performance in rough water is superior because of the roll and pitch dampening abilities of the keels. Any dual rudder design should be at least analized like a twin keel boat. From this it appears that water ballast should not be pumped side to side but rather remain in both sides to improve windward performance in rough water and the ballast should be low in the boat, like twin keels rather than close to where rail meat would sit. MacGregor Yachts claims to have invented water ballasted sailing sloops. Thier system is like twin keels, as opposed to the rail meat water ballast systems common on designs hampered by rules.
6. Not sure why you are convinced that there is some plot against MacGregors just because everyone but you knows they sail for s**t and are cheaply made.
You have been talking to your daddy. If you had been chatting with your grandfather, you would know that it is very common for new fiberglass designs to be sold for less than full value when they first come out. MacGregor Yachts told its Mac26x customers that they were purchasing a 40,000 vessel for 18,000 and this statement is consistant with what your grandfather might have told you.
Sail boat yacht producers, to get market share and enough boats to race, may initially price low figuring that as racing the model is promoted, demand will allow price increases. They also do not know what it really costs to produce because those costs are dependent on the number of boats created and warrentee related costs.
So your father may have purchased a new model fiberglass sailboat as an investment, thinking that petrochemical cost is always going up and hence the cost of fiberglass would go up and hence the manufacturer would have to up the price on later vessels of the same model type because of increased raw material costs. Furthermore the producer probably already intends to up the price as racing the model becomes more popular.
But here is the real kick in the arse. To get the manufacturer to up his price on future vessels of the same type even more, your daddy might nit pick while the boat is under warrentee. He might even encourage others to do the same by calling the boat a Piece of S**t. Those warrentee costs then go into the pricing structure and a 2002 boat in 2004 costs much more.
Your daddy then sells his used boat for a profit. How is that for a conspiracy? Damn Fine one I say. Your daddy would call it economics. The at first not similar fields (sail boat engineering and economics) become related when the boat is looked at that way.
BTW, Guzzwell told me the Smeetens had Tzu Hang? built as one way of getting wealth out of England. Roger Macgregor has likely pondered this notion. His undergraduated degree was in economics.
Those who do not recognize that conspiracy is the most popular explanation today for how things are in the US are doomed to TP52s
Thats a joke.
Anyway hope to continue the dialog. Can you tell my your generation? Are you Trophy, X, boomer? I promiss not to use the information to embarass you. I am 50 years old and just looking for a way to relate. Thanks.
