Towing a prop -- how to pick a prop?
Discussion in 'Props' started by Eric!, Aug 18, 2006.
  1. Eric!
    Eric! Junior Member
    Perhaps someone can help me sort out the issue of sizing a prop to a towed generator.
    I'm trying to estimate the pitch required to achieve a certain rpm when towing a prop for a generator.
    If I pick a boat speed, say 4 knots, that equates to 4857 inches a minute. Then if I choose a pitch that would spin at 500 rpm, the resulting inches traveled per minute would be 9.7 inch pitch for the prop. That assumes no prop slip.
    Is this the right way to look at this problem? How would I estimate prop slip? Would it be a function of the torque and diameter of the blades?
  2. Eric!
    Eric! Junior Member
    Since I'm not getting any responses perhaps someone knows the proper place on the internet to ask this question?
  3. marshmat
    marshmat Senior Member
    This is the right place, Eric, welcome aboard! Unfortunately the forum is so busy that on occasion a new thread gets lost from the New Posts page before it garners any replies...
    I suppose the formula you've come up with could be a starting point for experimentation, but I think what you'll find is that you will need to try several props to find the best one. It's hard to ignore slip, though. I can't think of any formula for a towed generator in water... perhaps someone else here can?
  4. Eric!
    Eric! Junior Member
    Thanks Matt. I'm not sure how much slip will occur. I suppose it depends on the torque created by the back EMF of the generator. For a starting point though, I think the slip would be low if it was just free spinning.
    I have a 9" pitch prop so I guess I'll just start with that. I don't have time for much trial and error and I figured this problem would be easy for a prop expert to help guide me in the right direction.
  5. Gilbert
    Likes: 5, Points: 28, Legacy Rep: 28
    Gilbert Senior Member
    I assume this is for a sailboat??? Why don't you run something off the prop shaft? Then you can tinker with all the variables with pulleys or sprokets or what have you.
  6. Eric!
    Eric! Junior Member
    Yes this is for a sailboat. I have a Yanmar engine and you can't let the prop freewheel on a Yanmar because it will burn out the transmission. Also I don't have enough room for adding a pully to the shaft.
    I'm really just hoping for some information about the characteristics of towing a prop.
  7. Eric!
    Eric! Junior Member
    Is this question posted in the wrong forum?
    Perhaps someone could suggest a book or article that might help me choose the right prop for this application?
  8. Frosty
    Frosty Previous Member
    I cant suggest a book Eric but I could suggest a little patience. You could go to the library if your in a rush, --do you have one in None.
  9. Eric!
    Eric! Junior Member
    Sorry if I seem impatient. No libraries here, I'm in mexico. I can't seem to find any information on this topic, which seems surprising. I must be making it too complicated. If I knew how a prop's torque and rpm are estimated based on free-flowing water stream, then maybe I could work with that.
    All the information I find on the web relate the prop to the shaft's rpm because that's were the power is coming from, but I'm trying to work it backwards and not having much luck.
    Once I leave this port, I doubt I'll have the opportunity to really tweak the chosen prop, so the best guess I can make now, the better.
  10. Guillermo
    Likes: 191, Points: 63, Legacy Rep: 2247
    Guillermo Ingeniero Naval
    Searching internet, I've found this book: "The 12-Volt Doctor's Practical Handbook" by Ed Beyn (Spa Creek Instruments, Annapolis, MD). I understand (Not sure) it describes how to do it.
  11. FAST FRED
    FAST FRED Senior Member
    Jack Rabit Marine sells a setup that has tiny outboard prop on a rope. Try google
    FAST FRED
  12. Eric!
    Eric! Junior Member
    There's several on the market, but I'm making my own. I just need some info about designing the prop for this application.
  13. Amador
    Amador Junior Member
    Dear Eric,
    Are you using a formula to define your pitch ?
    If you are , pay attention to the units, they may be :
    Speed foot per second
    Power HP
    Rotation per second.
    I raised this question because you mentioned speed in inches per minute and rpm.Regards Amador
  14. CDBarry
    Likes: 60, Points: 28, Legacy Rep: 354
    CDBarry Senior Member
    Look at "A Cruising Yacht", a paper by Curtze given at the Chesapeake Sailing Yacht Symposium in about 1976 or so and reprinted in Marine Technology. www.sname.org
  15. Eric!
    Eric! Junior Member
    Thanks. Is that Marine Technology Society or Marine Technology Magazine or something else? I was unable to find any abstracts under Curtze at both sites.
