Tool for recessing foam?
Discussion in 'Fiberglass and Composite Boat Building' started by shizlenut, Mar 22, 2011.
  1. shizlenut
    Likes: 2, Points: 0, Legacy Rep: 55
    shizlenut Junior Member
    I want to recess the foam on my build to leave space for laminate overlap. What is a good way to do so? I have tried sanding with an orbital but it seems slow and messy. would a electric plane work or be too aggresive? how have you gone about recessing foam?
  2. War Whoop
    Likes: 16, Points: 0, Legacy Rep: 84
    War Whoop Senior Member
    1708 ??? you are .045-.048 use a router and blend the little edges with a sanding block.
  3. gonzo
    Use the tool that is used for shaping surfboards. It is like a cheese grater
  4. War Whoop
    If you are gutsy a circular saw can be used,pulled sideways with the blade depth carefully set,You will need to guide from the back of the saw base ,straight edge screwed to the work,it does a clean job,practice on some scraps.
  5. CDK
    CDK retired engineer
    Use your wife's iron with the thermostat set for "cotton".
    To avoid domestic violence when see sees what you have done, put a thin sheet of mylar or baking paper under the iron.
  6. Herman
    Herman Senior Member
    You think that helps? You haven't met my wife...
    You're better off providing a new iron, but do not give it to her on mothers day, her birthday, or better still, under the Christmas tree...
    Best thing I have used is 2 battens, which can be screwed into the foam to act as a guide, and a router, with as large a bit as you can find.
    Afterwards smooth the edge with some sandpaper.
  7. shizlenut
    Thanks for all the input guys, I went with the router, does a great job. I will get some pics up soon
  8. thedutchtouch
    Likes: 2, Points: 0, Legacy Rep: 39
    thedutchtouch Junior Member
    in case people find this thread in the future, a hot wire foam cutter would also work.
  9. PAR
  1. Erwan
  2. aaronhl
  3. dougkenik
  4. brokensheer
  5. stringer bell
  6. nicste
  7. garrybull
  8. Cat Cruiser
  9. RTM
  10. brokensheer
