Titebond III testing
Discussion in 'Wooden Boat Building and Restoration' started by longfellow, Apr 20, 2009.
  1. PAR
    Tar and roofing cements can only be considered bedding compounds, not adhesives. Buehler designs use very littl glue, bolts, screws and nails are he's fastening systems of choice. He does recommend sheathing his plywood planked designs, but other wise he's a PVA, plastic resin or resorcinol man.
    Do your research carefully and select the glues you'll need for the specific application. Epoxy can cover a much wider range of tasks and doesn't require ti fits or clamping pressure to work well. This coupled with it's strength makes it hard to look somewhere else. No one glue gets it all done, but epoxy does darn near all of it, while the others can be left wanting in some situations.
  2. Boston
    Boston Previous Member
    glue lams are cheap and easy and come in any size you want
    as eliptical arch beams they are kinda pricey as Res mentioned
    but they may have some old molds that they made for someone elses project that approximate the arch you are after
    you might get lucky you never know
    the price goes from 6~12 bucks a foot to about 15 a foot for arched sections
    oh and the arches will not be radii of more less than about 20 ft either as those guys have no idea of how to steam bend
    the finger joints in those things are unbelievable strong and the glue is all you need specify to feel confident that thing would do the trick
    they will make whatever you want if you just make it clear what you want
    they probably already use an interior exterior glue but label them for indoor use only for liability purposes
    best
    B
    oh I dont think we ever used pine tar as a glue but often as bedding just as Par said
  3. rasorinc
    rasorinc Senior Member
    I should add that if you want curves or angles in a beam for frames it is quite easy to build your own Lams using 3/4" thick by 3,4,5,6,7,8,9,wide. You can bend 3/4" stock and using epoxy and 1 piece length boards you will have a solid beam. I made 20
    foot lams for beams in a Quansut HUT build I used 2x4s in a full 90* arch, bent one at a time untill shape was held. I was able to leave them 1.5" thick and bent them around pegs.
  4. Boston
    Bueler is a lumber yard builder if I remember
    he probably has a hole section in his book on glue lams
    back yard boat builder is the book I think
    oh
    my test pieces of pl glued are ready for boiling
    might do a few tomorrow and see what shakes loose
    I have
    red ceder to red ceder
    white oak to white oak
    and
    red ceder to white oak
    glued up and cured for seven days
  5. rasorinc
    Bos, I'll bet the weakest bond will be the oak to oak. What adhesive did you use? A guy told me awhile back that when gluing W. oak with epoxy he rough sanded the area then took a truss plate and hammered in into both sides of the joint to make a series of penetrating holes before clamping it under soft pressure. Never had a failure he said.
  6. PAR
    All three should fail in the wood fibers, if the clamping pressure and environmentals were sufficient.
  7. Boston
    ah
    no hints
    I need to find what I find without any preconceptions of what the results should be
    ok
    this thread is now off limits till I finnish boiling things
  8. Boston
    ok so the girl is off to work and I got a few hours to use all her nicest pots and pans to start boiling stuff
    unfortunately even if I use everything I made these test pieces a tad large and cant fit to many at a time on the stove
    that means my results are going to be scewed as the soak time ( 24 hours ) before boiling will vary between test subject invalidating the results to some degree
    oh well
    I just hope all the lovely tanins coming out of this white oak doesn't stain the girls pots and pans or the next thing boiling will be my nuts
    love
    B
  9. rasorinc
    Go rent a large soup pot, and a single electris burner and do it outside. It's better than losing important body parts.
  10. Boston
    2 hour boil
    LNP-901
    first group of pieces out of the pot
    2 of red ceder to red ceder
    2 of red ceder to white oak
    2 of white oak to white oak
    each piece was glued and clamped with 5.5 lbs per sq in for 7 days and then placed under fresh water for 48 hrs then boiled for 2 hours
    none survived
    in all cases the glue turned back to its original consistency and any pretense of adhesion was lost
    all 6 pieces failed the boil test
    6 pieces were not boiled
    they were tested soaking wet for strength of bond under direct load only
    each piece failed with the application of 70 lbs per sq in or less
    none survived more than 70 lbs per sq in
    the average being ~50 lbs per sq in
    manufacturers specs claim
    Shear Strength: ( dry )
    24 hours – 225 psi
    48 hours – 300 psi
    7 days – >425 psi
    with the red ceder to red ceder bond being weakest and the white oak to white oak bond being the strongest
    this may have been something to do with the permiability of the wood to H2O not of relevance to the performance of the glue
    my conclusion would be that this glue is completely unsuitable for structural marine use
    B
    ps
    the pots turned out ok
    the girl need never know
  11. Jimbo1490
    Likes: 41, Points: 28, Legacy Rep: 527
    Jimbo1490 Senior Member
    Looks like back to epoxy. Choose an adhesive with a simple formula; BPA resin, cabo-o-sil and a polyamide curing agent. Polyamides give you 'rubbery' cured-state properties, with very high fracture toughness and elongation. Their high mix ratio (typically between 1:1 and 2:1) and high viscosity is ideal for a hand mix adhesive. They are also extremely forgiving of mixing errors, giving close to the same properties with errors of 25% on either side of a 'perfect' (stoichiometric) mix. They are considered low toxicity and low sensitizing. You won't need to add any reactive modifiers (these are all 'highly sensitizing') as you do not need either lower viscosity or more fracture toughness/elongation; you've got plenty of both.
    The 1:1 Glue from Fasco is just such a product. Both components about like vaseline in consistency. Long work life, overnight cure. Very low odor.
    Jimbo
  12. MichaelC
    MichaelC Junior Member
    Okay, so in the absence of any glues that will work for sure underwater except epoxy, which I can no longer use, I guess it is wholebunchabolts time. So I will use pine tar as a sealer, not a glue, and bolt the bejeezis out'n it. We all sure appreciate your testing system, Boston. Nice work. Glad to hear her pots and your nuts survived intact.
  13. ancient kayaker
    Just varnish the sucker until it glows, and dry it after use. The boat that is.
  14. rasorinc
    Bos, go with the best, proven, epoxy adhesive mix. Save on the cost of aplying the 3 protective coats if you are going to go that route. Don't save on the adhesive. Glen-L offers Poxy Grip at a fair price and have decades of experience with it and 1,000s of boats built using and it is middle priced. I'm using it but will go with RAKA for the coatings. It is a 1 to 1 mix with either fast or slow hardiners or a combination of both. Lots of info on it on their site. Used to build 8' to 60' boats and proven. That's all. Best, Stan P.S. It has been boiled to death and does not fail. click on epoxy. http://www.glen-l.com
    click on boat building supplies for price. Just info for you. The only other adhesive (epoxy) I would consider is West. but $$$$
  15. ancient kayaker
    System Three have the Silvertip range of adhesives that also come in a self-mixing dispenser that fits a caulking gun. Use with a disposable mixing tip. Rather expensive, but no mixing, extremely convenient and quick, and much easier to prevent skin contact. The Gelmagic one is nice, non-sagging, stays where you put it. You should still use protective gloves of course.
