717innovations
Junior Member
- Joined
- Sep 13, 2013
- Posts
- 16
- Reaction score
- Location
- Pa USA
I'm currently working on a race car roof that in order to get the rigidity I need I'm going to hafta use a balsa core. I can post pics if needed. The roof is like most cars it's has a 1/2 rib running from front to rear helping gain some rigidity however the customer wanted the middle to be flat the area of the flatness is roughly 3'x4' I have tried foam strips running front to rear in the middle and also an X out if foam strips but they do not seem to stiffen the laminate as much as needed. Another factor I have is weight. They want to keep them in the 6-7 lb range. My current layup is gel, 1.5 mat 1/4x 3/4 foam core strips in and x and 6oz cloth comes in at 7.6lbs and sitting on a table if I pick any corner up it flexes about 6 inches before lifting the rest of the roof. I have no experience with a balsa core. I have 1/4" 2x4 sheets I was planning to cut to size. Could anyone lend advice to how to use them in a layup. I plan to drop to 3/4 mat under the balsa. And 6oz on the other side. I prefer to not have to bag the part to keep cost down but I don't want any issues with the balsa not bonding. Thankyou I'm advance
