Thrust differences between petrol outboard and inboard diesel of same horsepower
Interesting about the need for a different number of blades and smaller diameter - I will keep an eye out for that - thanks!
Different number of blades to avoid rhythmic fibration caused by all blades crossing simultaneously, and smaller diameter, because the stream from the first prop contracts, as Bernouli first described.
What country are you measuring the boat to be registered in? I thought this was for the USA.
Egypt, but the 38' foot boat in the youtube video I linked to is a USA vessel - so I wanted to know how the 38' was measured so as I can then do some scaling off some stills taken from the video.
I take it you are not familiar with USA regulations.
Could you please explain to me which USA regulations disagree with what I'm saying? It won't be difficult, given your in-depth knowledge of USA regulations, and it would be very helpful to me. Thank you.
In the USA it would be measured between perpendiculars. That includes bowsprits and swim platforms.
I beg to differ with that method of measuring length. It's a matter of having clear ideas. When you design a boat, you'll have no choice but to clarify them. In my country, which doesn't tend to innovate but simply follows what international organizations propose, the length between perpendiculars, although we know how to measure it, is no longer used. You can check, if you'd like, that some other international regulations don't use it either.
In any case, it is a serious mistake to include the swim platform or bowsprit in the LBP.
It is not a mistake, it is the way it is done.
It's a huge conceptual mistake. (End of discusion).
All rules are a mess and - a mistake.
You would know that if you are familiar with more than one statutory set of rules:
I beg to differ with that method of measuring length. It's a matter of having clear ideas. When you design a boat, you'll have no choice but to clarify them. ....
You can beg all you wish, but other countries have different rules.
Helps to look beyond your shores...
