yachtnetwork
Junior Member
- Joined
- Apr 8, 2012
- Messages
- 25
- Reaction score
- Location
- Florida
Ok guys I am looking for other ideas or perhaps suggestions here.
I need to convert the stock throttle actuator on a project to a more basic 3300 Uflex style cable system like found on most boats. We need to adapt the system and it will need to work with a 2' custom Mach 0 Ultraflex cable.
Right now the range of movement (stroke) on the stock actuator is approx 7/8" from fully opened to fully closed. It will need to mount to the inside wall of a console where full forward is closed and full back is wide open.
The cable that we have to work with has a range (stroke) of 3-1/2" from fully opened to fully closed. I am trying to figure out what the best way to make them work together is and make it look pretty. I had an idea of building a frame for the throttle actuator and somehow extending the actuator arm to coincide with the 3-1/2" stroke we have to work with on the throttle cable, however I am looking for any other input or suggestions. Pics attached of what we have to work with. The actuator is mounted on a junk piece of starboard so you can see if easier.
Also I will save anyone the trouble. We do NOT have the option of just using a squeeze trigger throttle or anything like that. We need to use an all in one control box throttle and shift unit to coincide with the rest of the boat.
Thanks for any input.
