You've got your footnote markers reversed. Also, one of the more popular sails for the PDR is the Bolger 59, a leg-o-mutton rig he spec'd for several of his small boats.
Aside from that, I'd like to know more about the 3xx-class boats. I got an offer of a complete free PDR, but it won't fit in the bed of my pickup, which measures 39 1/2" between the wheelwells, and I will not consider trailering. This is causing me to consider just such a design myself, and I'd be comfortable with the extra length as well. If I do this I would plan to use a junk rig on it because it reefs instantly and can use a shorter mast. See here:
The Junk Rig Association - Cash prize of 250 GBP - Dinghy Design Competition https://junkrigassociation.org/technical_forum/10211344
Are you going to use a stretched version of the PDR's hull curve, or something different?
Finally, of all these boats you've designed, how many have you built and sailed, and what did you like or dislike about them?
If you don't have a cap on your pickup, you can probably fit 2 pdracers in there. Just put them in on their sides.
Yeah, the Bolger 59 rig is the most popular, followed by various forms of the balanced lug rig. But if you want to win a race, you need a bigger rig. The beamy hull can easily handle it. When Mike Storer came to the US with his version of a pdracer, which was completely class legal at the time. He blew everyone else away. His boat was well engineered, light (around 55 lbs IIRC. A typical boat weighed closer to 100 lbs ), had a 79 sf rig, and its rocker cut was about 1 inch shallower than the intended design, but within the class tolerance of the time. I think his superior performance was more due to the weight of the boat and crew and the large sail area than it was to the rocker cut. But still. this caused a huge dust up which crippled the class. Shorty cranked down on the rules hard. The tolerance got reduced to 1/2 inch. So now, all the boats built to the Storer design became illegal. This broke my heart, even though I didn't have a pdracer myself. If I had stuck around in the group, I may have been able to help prevent this.
As it is. I have had this idea of a 3 ft wide class for some time (more time than I'm willing to admit), and I have decided to start it as a developmental class, with a mind toward internal handicaps, if some boats turn out wildly superior to others in the class. So there is no defined bottom (rocker) shape. There is a requirement that hull profile fit in a proportionate polygon (see attachment), without any portion of the hull crossing any of its lines.
The sail area will be in proportion to the weight of the boat and crew, rather than a specific sail area. The formula for this does not require a scientific calculator. I'm doing this to avoid creating incentives to make the boats as light as possible. There are plenty of other classes that do this. I think it's time to try something different. I also want to avoid ever towering rigs that complicate set up and use of the boat, so I added a requirement that all the spars, including the mast, must fit within the hull when taken down. multi-piece masts are forbidden.
There is a high likelihood that some boat and crews will weigh as little as 200 lbs and as much as 600 lbs. People come in all shapes and sizes. The heavier boats are also going to be the longer boats, but are going to have proportionately less initial stability, due to having deeper sections. But this higher initial stability, in the shorter, lighter boats may not make up for the greater theoretical hull-speed of the longer, heavier boats. So I'm working on a length handicap. So, this is all I'm willing to say about the rules I'm developing at this time.
I share with you an interest in easy reefing. My boat has just one reef point, but should be able to reef while underway. Its rig does somewhat resemble a Chinese lug, but has only two boomlets (sometimes called battens). The top one is lowered onto the bottom one, a snugging line is pulled and cleeted, and the job is done. The sail area is shortened by almost 50%. I have already built this contraption. I hope it ends up working.
And no, I haven't built any of these boats I have designed. The one I'm building now is the first boat I will have built in almost 50 years.
