Is there a negative in using sawdust as a filler to thicken epoxy for bonding wood together instead of using a commercially sold filler?
I'm thinking that using sawdust as the thickening agent, the epoxy bond will still be stronger than the wood being joined and if the joint is pulled apart the wood being joined will fail instead of the epoxy.
I'm going to build a 12 foot plywood jon boat but never having used epoxy to build a boat before, I'm looking for opinions from experienced boat builders. Thanks.
