This is not the first hardtop i have done, the last one i built was for an outbound 43 but was quite a bit smaller and i was free to put a decent camber in it, (3/4" to the foot if i remember right) i used a 3/4" balsa core, matched the boats gelcoat color and turned the edge down so the visual thickness was 2" and we could hide the channel for the roll up sides, i did run conduit in the core for lights and for the wiring for the solar panels and also molded in cutouts and bosses across the back edge to accept a 1" ss tube which we bent in 2 planes as a hand hold, it was quite tricky as it required parts of the mold to come apart with the part because of both concave and convex radii, i also molded in a recess for a fixed lexan window for viewing the sails and windex,it was very sucessful and looks like it came with the boat which was the goal. However, this one is bigger and may be restricted to the camber of the radar arch which will support it about 2-3ft in from the aft edge, i would like more camber and will push for it.
Edmund, for a female molded part polyester or vinylester makes much more sense to me, i can have gelcoat mixed that is a perfect match to the boat and not require a tie coat,i personally believe that one can achieve a better resin/glass ratio (in a hand layup) with poly, it just wets out better than epoxy, it is much easier and faster to work through the process without having to wait forever for epoxy to cure and not having to deal with blush if you miss your time windows (due to slow cure) Epoxy and styrofoam would not work at all in a female mold situation, while epoxy does bond to styrofoam after a fashion the shear strength is very poor and the foam itself is weak, as i explained, this top has less camber and less supports than i would like to see which is why i am looking at using a thicker than usual core and when you go very thick with the core i feel you also need a core that is not going to shear within itself, if i were using foam i would probably want to go a little more dense than the usual H80 although if i were to laminate 2 layers, maybe not, anyway this is why i will probably use balsa. This top does not need to take a lot of impact so it doesnt need thick skins but it does need to be able to support a couple of women sunbathing, not jumping around, i am going to try to talk the owner into a post off the steering console,that would do more than anything to stiffen it.
Steve.
