what are you trying to do exactly ??
I have been watching this post for a few days and am at a loss and not really sure what you are really trying to achieve !! so you already have a existing boat now and you want to lay more glass over the top of what's already there !!
simple question
WHY
is the boat weak in the bottom ??
is it thin ??
does it move a lot up and down ??
If it moves then how much does it move ??
Do you realise that movement and flexibility in some glass panels and glass structures is actually a good sign and that it is stronger and will take more abuse and punishment than the same panel that has little to no movement at all ??
Remember this from olden times !! a tree that bends in the wind looses no branch's !!
but one that is ridged and does not bend or move with the wind usually breaks and dies !!
Glass is very similar !!
To lay new glass over a old surface the old glass will need to be sanded or ground 100% to be sure of getting a good secondary bond onto the old surface !! any unground areas are the most likely places for delamination to start and eventually spread !!
Sounds like there are structures you are wanting to go over the top of !!
CAN YOU POST A PICTURE OR TWO SO WE CAN SEE WHAT THE PROBLEM IS ?
It maybe better and easier to cut the glass into strips of useable widths and use the joining overlaps to get even more strength in the layer of glass than trying to lay a great long wide strip all in one go . personally I would not even attempt such a thing . there are limitations that even a really a good professional glass person can do and by the sound of what you want to do is not one that I would choose even with 3 or 4 people helping !!
