How would you compare it to polyester? I think I've mostly used polyester and and that cures pretty quickFor foam sandwich Vinylester is a brilliant resin. Faster gell and cure times make for much faster and time efficient building.
Note: This feature may not be available in some browsers.
It works the same as polyester with an MEKP catalyst but it is more epoxy like in properties.How would you compare it to polyester? I think I've mostly used polyester and and that cures pretty quick
If you are worried about abrasion, you build the Skoota with a beaching keel.Im interested in building a composite Skoota myself but with polyester resin and mostly nidacore. I want to be able to get in and around very shallow areas and the possibilities of rot mixed with the thinness of the plywood and laminate makes me worried about scratches and impacts taking their tole on it and leading the boat to an early grave. Im a super new member so I cant send direct messages yet but Id really like to be able to talk to you in depth some time about building yours.
Indeed what I've been increasingly finding is that under the waterline I would need some kind of substantial reinforcement if I used nidacore. I was considering a second, but much thinner layer of more impact resistant core material before the external layup and/or lamenting an extra layer of kevlar below the waterlineIf you are worried about abrasion, you build the Skoota with a beaching keel.
You don’t use nidacore if you have abrasion concerns. Hole that stuff and you get a wet core.
I used plascore (similar) for the bdeck, but only for its size at 5x10. I regret making a double bottom and the weight added is really enormous. I think an elephant could walk on my bdeck if the cat wouldn’t sink.
Kevlar and other exotics are wasted with polyester, the resin system shatters before the material gets even close to its load limits, again, vinyl ester is a better fit.
Isn't that exactly what Kelsall did with his KSS system - including shapes with round bilges?but how do you get the infused flat panels to bend into a "boat-shape"? They are sandwich & very stiff...?
That said I still have conclude:
significantly better boats can be built with the same investment of money & labour
