Tell, me what exactly is the "typical sailing cat"?
A typical sailing catamaran in the 10-13m range. As noted, unless of course you wish to provide the GZ curve of the cat's you posted to be more "accurate" as you seem to imply?
Yet you show the "typical sailing cat" sailing at 2 degrees in the approx. 50 knots of wind that the report says capsized WingNuts.
Whats wrong with this picture?
Your understanding of your own question.
Where does my GZ curve state it is a 50knot wind? It doesn't. You claimed that cherry picking is present in racing, viz:
I just think there is a double standard being applied-
The curve shows quite simply a wind producing a wind heeling moment. The wind can be ANY wind you care to select. Your premise is that there is a double standard. Given a nominal wind heel, when overlaid onto 2 very different vessels, the result is clear to see. One would capsize, the other not, by a very clear and obvious margin.
So, please explain where the double standard is..?
