The Mast as a Problem: a Legend
CarlosK2
Senior Member
Joined
Jun 1, 2023
Messages
1,638
Reaction score
127
Location
Vigo, Spain
Fabio Fossati (-2015), may he rest in peace, Wind Tunnel of the Polytechnic University of Milan, micro pressure sensors
At AWA 20, we can observe a slight increase in pressure in the MainSail low-pressure area due to the Mast effect, a minor detail: note that, as we know, sharp leading edges on the jib or genoa are not ideal
And look at the mainsail at AWA 35
The Mast as a problem is an old myth
Mikko Brummer - Wikipedia https://en.wikipedia.org/wiki/Mikko_Brummer
Mikko Brummer has repeatedly pointed out the positive effect of the mast on this forum, and once, in a CFD study of a case, he gave a figure: the mast produced 6% of the sailboat's forward thrust
Intrigued, I did some simple calculations, and in the case studied, the mast produced 4% of the sailboat's forward thrust.
The mast (along with the mainsail and the headsail) becomes a sail that isn't very efficient, but a sail nonetheless
AWA: 30°
AWS: 16.87 (TWS @ 10 m h: 15 knots)
Lift: 67 Newtons
Drag: 20.8 Newtons
Drive Force: 15.69 Newtons
Lateral Force: 67.5 Newtons
The boat travels at 5 knots, propelled by a force of approximately 400 Newtons, which is not shown in the drawing
What if its a box-spar? Effective down wind for sure.
Areofoil shape and wingmast sections i can understand being some drive.
In summary: for 30-35 AWA, a rig consisting of one mast and two sails is excellent.
And if the Mainsail is worthy of the name and quite large, then it's a rig that's also suitable for downwind sailing.
The mast as a supposed problem is a clear case of self-sabotage and making a mountain out of a molehill
+ a better shape
+ a realistic AWA for most yachts; we're not talking about skimming across ice
+ a boom and a MainSail
+ the downwash of the staysail
and the supposed problem dissolves like a sugar cube in a cup of hot tea
"a box-spar"
Exactly
Four Sitka Spruce planks, epoxy resin, and three coats of polyurethane from two cans, along with Dyneema* shrouds and galvanized turnbuckles
Simple, reliable, and mechanically clean, without the hassle and nightmare of a rig based on a very expensive Aluminum mast
*: There are two possibilities:
Plan A) pure or
Plan B) with a Dyneema core and polyester shirt
Plan B seems like a magnificent solution to me: the Dyneema soul well protected from the sun and friction
Actually, the main criticism of the single-mast, double-sail rig is: what's the point of having a mainsail for those snail-yachts that carry their entire house on their backs if they're not going to hoist it?
Plenty of snail-yachts have sailed around the world without ever raising their mainsails
Why on earth would they want such a mechanically complex rig, prone to failures, mechanical scares, and crevice corrosion of the stainless steel
Crevice corrosion - Wikipedia https://en.wikipedia.org/wiki/Crevice_corrosion
A mast made of four Sitka Spruce planks, well waterproofed with epoxy resin, the resin well protected from the sun with polyurethane.
Completely enclosed, without the superstition of drilling holes in the mast to hide the halyards
the mast is sacred; drilling holes in it is barbaric, and then letting water in—are we crazy or what?
Damage the mast for 4 fuxxx Newtons of Aerodynamic Drag ... Upwind
... and then install large solar panels facing the wind, a zodiac at the stern, and a large awning ... this yachting world tends toward madness
Freed
Freed from the (silly) Aerodynamic fear of the Mast...
we can opt for a mast 2 cm large and it turns out to be lighter, the same weight, or slightly heavier than its aluminum equivalent, and much much more resistant
From a simple version 1.0, a simple rectangle (12 cm x 10 cm) of four Sitka Spruce planks, to a possible version 3.0 with a hollow Paulownia nose, there are many possible variations
My last big spar, 3 layers, hollow, aluminium chafe in the top 2m.
Its lost a further 3kg in weight while being stored over the past years.
This thread seems like a bunch of random postings about masts.
What exactly is the "problem" that you're trying to refute?
