Thanks Skyak. I am still very new to sailing and have very little practical experience, so take anything I say with a pinch or two of salt.
I have, for instance, realised since my last post that the reason for the "boat" to reach its max L/D only at high CL values could rather be as a result of the high "base" drag of the hull and sailor. The sail itself reaches its own max L/D at much lower CL values.
The spreadsheet still needs some refinement, especially since I had to use fudge factors for it to match the real Laser polars. It is important to give every variable the proper weighting if any reliable results are to be obtained from scaling or deviation from the standard rig design. I will make it available eventually.
Will, I recognize several of your insights from theory and practice. As sailors go I am more theory than experience myself but I have not managed to put together a complete monohull model. Fudge factors are acceptable in my level of work as long as long as the variable I need to tweek isn't in the fudge. My interest is not so much about accurately modeling current designs as it is about finding value in what should be -like closing off to the deck or is there a better control variable than just angle of attack like a flap and or a slot. I also want to quantify how difficult it is to sail a boat -how much control does it take per variation in wind.
Keep up the good work! I am looking forward to the spreadsheet.
