The best marine head
Discussion in 'Boat Design' started by daveschile, Aug 25, 2005.
  1. Brad Kelneck
    Brad Kelneck Junior Member
    Best marine toilet
    Hi:
    I agree totally with Jim - the Lavac marine heads are absolutely the best and most odour free and reliable on the market. The have the added advantage of functioning as a spare bilge pump with a y valve installed. The large size pump ensures you don't get blockage and they are incredibly easy to use. The only negative is that they do use a fair bit of water per flush.
    Numerous upscale builders are now specifying them and, when they do, they inevitably merit mention in the boating press; see, for example the review of the $838,000.00 Bruckman 50 in August 2005 edition of Blue Water Sailing.
    They are available at Defender Industries over the net and are quite reasonably priced.
    Brad Kelneck
  2. MikeJohns
    MikeJohns Senior Member
    I have to add my accolade for the Lavac.
    Simple reliable and long lasting they are always my recommendation to anyone who asks, and I wouldn't install anything else.
  3. mattotoole
    mattotoole Senior Member
    I don't have much experience with the others mentioned here. But the two Raritan electric macerator heads we've had in heavy service for the last 7-8 summers have given us absolutely no problems. They use seawater and work fine with normal toilet paper. While some butthead will always manage to clog any head, these will always clear (and not overflow) if you just shut off the inlet valve. In comparison, the manual heads I've always used are a joke. I'm sold.
    I don't understand freshwater heads -- what a waste! Why not seawater?
  4. FAST FRED
    FAST FRED Senior Member
    "I don't understand freshwater heads -- what a waste! Why not seawater?"
    At least 2 reasons , the seawater salts slowly accreate (build up) inside the piping , eventually requiring replacement or some sort of chemical cleaning.
    A modern RV head (Sealand) is best for no discharge areas as it flushes with a half pint of water , rather than a half gallon.
    FAST FRED
  5. yipster
    yipster designer
    Fast Fred,
    that salt builds up only very slow and occasionaly you can drop a tablet.
    i have a simple 1 meter hose out, the only time i easely replaced it was to accomodate an electric pump.
    do remember though the shop saying its a special smell sealed head hose.
  6. kjell
    Likes: 5, Points: 0, Legacy Rep: 31
    kjell Senior Member
    If you are using sea water in Mediterranean to flush your toilet you will have problems. The warm salty water is building up a hard scale in the pipes and on the valves in the pump, making it impossible to use the toilet. The only toilettes that works are the sweet water toilettes like Sealand and they are using very little quantity of water so you don’t need big holding tanks.
  7. stevel
    stevel Lost at sea
    Saltwater toilets also cause smell problems if they sit for long periods of time between uses. The once-living things in the water smell bad as they decompose.
  8. Lecter
    Lecter Junior Member
    Has anyone anything to say on the notion of composting and retreiving methaine on board?
    PS: Sorry if my spelling isn't so good.
