do you think I should give up on the alternating layers and just make it a thicker Coosa board and then do my lamination entirely on the outside or do you like the idea of the alternating sandwich?
A friend of mine in Alaska knew these guys who did a transom repair. The boat broke open and everyone perished. Most likely they failed to tab the transom layers into the hull well enough.
The way the transom on this boat is designed gives me major pause because you cannot tab glass to the hull around the 1x4s.
My friend and I both tend to be willing to throw the red flag, but we are both not comfortable providing laminate schedules. Someone inevitably will do poor work or poor tabbing back into the hull and end up at the bottom.
My boat has a much narrower hull, a slightly poorer core of 1.5" and was built with 4 layers of db1700 on each side with overwraps over the top to 8 layers and wraps to the hull of 10,8,6,4 all around, inside and out.
So, you need to exceed that for a wider transom.
But I really am not qualified to do more than get off the boat before it leaves the dock if I don't like the way it is built.
Since the construction method here is not monocoque; I am even less suited to tell you how to build it.
Someone here may jump all over me for this is pof vs monocoque and core, but the mix and match of coosa and pof is the hesitation for me..
Basically, you have a light glue bond holding the transom on.
