Testing hull thickness
Discussion in 'Materials' started by jenevers, May 31, 2019.
  1. jenevers
    jenevers Junior Member
    Is it possible for surveyors to test hull thickness these days, without having to use a grinder to create a clean surface? I once saw one grind a good 2 millimeters away before taking a reading! Not my boat I might add!!
  2. rxcomposite
    Likes: 635, Points: 113, Legacy Rep: 1110
    rxcomposite Senior Member
    Is this steel?
  3. jenevers
    Yes.
  4. rxcomposite
    They use ultrasonic thickness tester approved by the surveying body. Class surveyors do not grind away materials. They ask the shipowner/Master to prepare the surface for testing either by sandblasting or wire brush. 3rd party surveyors do carry a small pick and hammer but only to expose the metal by chipping away rust scales. Only enough for inspection. I have never heard of a surveyor resorting to grinding as the thickness tester will show the state of the plate anyway.
  5. gonzo
    Likes: 2,273, Points: 123, Legacy Rep: 2031
    You need to remove paint and oxidation off for a proper reading. Grinding off 2mm of metal is excessive. On unpainted steel we only scrape off the loose material, particularly when testing underwater.
