TEOTWAWKI Boat
Discussion in 'Boat Design' started by hoytedow, Apr 20, 2012.
  1. Yobarnacle
    Likes: 129, Points: 63, Legacy Rep: 851
    Sounds like a plan. :)
    Or at least a seminal idea. :D
  2. Frosty
    Frosty Previous Member
    So--this is where you are Yobiboob hanging with Hoyt.
    A perfect place for you.
  3. hoytedow
    Likes: 352, Points: 93, Legacy Rep: 2489
  4. Yobarnacle
  5. hoytedow
    That's knot funny! :D
  6. philSweet
    Likes: 252, Points: 83, Legacy Rep: 1082
    philSweet Senior Member
    gallows houmour
  7. hoytedow
    How the bows were secured prior to gluing:
  8. hoytedow
    I read that moving the engine forward slightly will help reduce squat. Opinions?
  9. Ad Hoc
    Likes: 912, Points: 113, Legacy Rep: 2488
    It shall do one of 3 things:-
    1) Better
    2) Worse
    3) No change.
    Without knowing what your weights and centres are and the hydrodynamic characteristics of your boat shape (i.e. an LCG chase from tank testing), I can't say which it will be.
    But, typically on low L/D ratio hulls forms moving fwd helps.
    hoytedow likes this.
  10. hoytedow
    Thanks. No tank testing is planned. The way the engine is mounted, it will be a simple fix to move it fore and aft to achieve best performance.
  11. philSweet
    Unless you have remarkably long arms, better to move it forward some. Is 18" doable?
  12. hoytedow
    18" is doable but not necessarily desirable. I will save that option as a last resort.
  13. Ad Hoc
    Good call. Don't cure a "problem" without knowing if it is indeed a problem.
    Leave all "what if" debates until the boat is in the water and running. We can all debate the does and dont's, but it is just theory until the boat is in the water and running. In the absence of any facts best leave as is. Then, when sea trialed it becomes a fact rather than conjecture, and you'll know what, if anything, to do :)
  14. hoytedow
    Thanks, Ad Hoc. Having built a similar boat some 40 years ago, I am not too worried as the predecessor performed well.
  15. ancient kayaker
    What's with the name? It it doesn't seem big enough for the end of the World . . .
  1. Adamhunt1
  2. BigBull
  3. Squidly-Diddly
  4. mustafaumu sarac
  5. SummerSchool
  6. jdray
  7. Scott Redington
  8. comfisherman
  9. LandFish
  10. Iridian
