Ten Years of Hard Use, Exposure and Neglect -- What Worked and What Didn’t
Discussion in 'Wooden Boat Building and Restoration' started by Bob Smalser, Jul 18, 2011.
  1. Bob Smalser
    Likes: 11, Points: 0, Legacy Rep: 159
    Bob Smalser Junior Member
    Over a decade ago I built the John Gardner-drawn 12’ Dion Punt below to use for swamp-logging in beaver ponds; a tender for setting the tongs and chokers used to grab the logs. The advantage of this design is that beaver ponds are full of stumps you often can’t see because of the dark swamp water, and they regularly hang up heavily-loaded conventional skiffs so badly you have to get out and push. According to Gardner, this boat was patterned after large cranberry bog punts used to transport heavy loads that sometimes included the draft horses they were towed with, and is purposefully more buoyant in the bow than in the stern. With this boat, when you get hung up on an obstacle, you merely move to the rear oarlocks and row off…without problems…one of those rare, “Voila!” moments, well worth the two weeks it took to mill the lumber and build the boat.
    Boatyard owner Fred Dion designed and built the first one of these in the 1930’s as a tender for his two marine railways in Salem, Massachusetts, marine railways also having underwater structure prone to hanging up skiffs. The boat’s sides are smooth so laps can’t catch on structures in a swell, and the scantlings on this boat are extra heavy for stability, impact resistance and all-around commercial use. This is hardly a sport boat, as it weighs over 300lbs when wet. I followed the design almost exactly, only substituting Western Red Cedar over Douglas Fir for the original Eastern White Pine over White Oak. Not only has this boat been used hard, when not being winched from the water and onto a heavy-equipment trailer behind the skidder, it has lived at a mooring out in the weather 24-7-365. When not in use, we simply let it fill with rainwater at its mooring and even freeze in the ice as less work than winching it out regularly. You can see the average waterline indicated by the white algae stains on the boat’s sides. Further, the only care the boat has received in the decade+ it’s been in the water or tossed around with heavy machines are minor topside paint touchups to protect it from the baking summer sun here. Finally getting around to beaching it for proper repair and repainting after a decade+ of abuse is a good opportunity to study which boatbuilding techniques worked well…and which techniques did not.
    A short aside about letting it freeze in the ice. Ice takes up more volume than its equivalent in water. If you allow rainwater to fill a boat so the water levels are equal inside and outside, allowing it all to freeze won’t harm the tougher boats out there. But if the boat has been recently used and is pumped out, allowing it to freeze in substantial ice can crush it.
    The Prize.
    A migrating beaver family dams up a likely stream bottom at the end of a forested basin; the water rises and drowns the trees, which eventually rot off at the base and fall over. Over time the dam silts up and becomes a permanent pond, with some centuries-old dams a hundred feet long and forty feet thick looking like they were made using a bulldozer. The cottonwood, hemlock, willow, alder, maple, bitter cherry, crabapple and other non-durable woods rot quickly, and along with tree litter from the surrounding forest, become the deep humus on the pond bottom. The more durable Douglas Fir and Pacific Yew become the mat of slowly-disintegrating snags floating on top of the water, and the cedars eventually waterlog and sink to the bottom. In these three recovered, old-growth cedar sawlogs bucked to 12’ above, there are (among other uses) around a thousand linear feet of vertical-grain siding custom-milled to match that on old houses, and represent a substantial return on investment.
    Western Red Cedar. Often maligned as too soft and too brittle for optimum boat planking, I find in the 7/8” thickness used here to be incredibly tough, durable, resilient and easy to work. In fact, if I ever build another of these punts I’ll use either Western Red or Alaska Yellow Cedar in a slightly thicker scantling for the transom, bow stiffener, guards and even the inwales instead of Douglas Fir. Both cedars are more rot resistant, hold paint better, don’t check or exfoliate when left unpainted in the sun, and in collisions and abuse don’t split and splinter anywhere near as easily. It’s like hitting a stump with a bag of sand as opposed to a caulking mallet. Nor do I find Western Red to dent easily when properly coated; it tends to bounce off instead. That it doesn’t hold screws well can be fixed by saturating the pilot holes with epoxy thinned by solvents or heat before driving the screws.
    Rough-Sawn Lumber.
    I milled the lumber for this boat to Gardner’s exact scantlings with an appropriate shrinkage allowance without thickness-planing it, and airdried it for two years before use. The rough surfaces worked very well as a key for paint, bedding or fairing compound, were easily belt-sanded in the few places where smooth is desirable, and not having to run all that lumber through the planer while fussing with finished thicknesses saved at least a day in construction time.
    Second-Growth Lumber. I had a few pieces of high ring-count, old-growth fir I used for the transom, inwales, bow stiffener, and thwart knees…otherwise all the cedar and fir was second-growth, generally 8 rings to the inch or better, and vertical grain from large, mature, 80-year-old trees. I found no advantage at all to the old-growth in resistance to rot, checking or splitting. Of the three knees I replaced because of rot, one was old-growth…and the part I’m having the most trouble with is the old-growth, quartersawn, Doug Fir transom, which doesn’t match the seasonal stability of the similarly-cut cedar sides, and accordingly, has minor splits in two places requiring repair.
    Hot-Dipped Galvanized Fasteners.
    If yours is to be a fresh-water boat, they can save you significant money over bronze or stainless providing you take some precautions. Bed the pilot holes in thinned epoxy or red lead and goo, and they will hold up better than those on the left in the photo. I was in a hurry, only bedded a few pilot holes, and a decade later you can easily tell which ones. Skip those steps and they rust like their counterparts on the right…the acid in the cedar attacks the zinc as well as does retained water attack the steel beneath. Where you can use them, galvanized steel fasteners are a distinct advantage come repair time, as they are the toughest of all of them. A common brace chucked with a screwdriver bit backs even the stuck, rusted ones out easily. In turn, the heads of softer bronze and some stainless grades like to strip when the screws stick, and bronze screws twist off much more easily. Depending on boat size and how it will be used, the cost difference between metals can be significant. The price ratio between hot-dipped galvanized to 18-8 stainless to silicon bronze is typically 1 to 3X to 5X, and this boat used a dozen or so boxes of #10’s, #12’s and #14’s from 1 ½ to 2 ¼ inches long.
    For greater economy and speed, the boat could be nailed together and have the same longevity, it just wouldn’t be as easy to repair. I prefer bronze ring-shanks because they are soft…a pry bar and a hacksaw blade make disassembly almost as fast as a brace and galvanized screws. Once cut, the head is driven out with a punch and the pointed stub is countersunk into the wood to remain forever. Stainless ring-shank or box nails aren’t anywhere near as easy, and are almost as expensive. Galvanized boat nails are also an option, but nails don’t bed as easily as screws and won’t last as long as a well-bedded screw.
    And if you like to use a brace for screw chores as I do, I recommend you find an 8-incher on eBay (or even wait for the rarer 6-incher) for driving to supplement the 10 or 12-incher you probably are using for removals. Few out there value braces as user tools today, and even the rare ones go relatively cheaply. Smaller, lighter and surprisingly handier, the tiny 8-incher replaces the Yankee Screwdriver entirely in many instances…only with much more power, more precise control, and less carpal pain…plus saving you the step of rigging a different tool for many tight spots.
    Continued…
    4 people like this.
  2. Bob Smalser
    Rope Bumpers.
    They can both lengthen the life of the sheer guards by providing padding from bumps, and also shorten the life of those guards if you don’t properly bed the screws or marline holes used to mount the rope. I failed to bed all those #6 stainless screws, allowing lots of water ingress from the slow-to-dry rope…and the Doug Fir guards rotted well before their time.
    Ramin Dowels.
    I used some store-bought Ramin dowels to reinforce a few places in the cedar instead of my usual practice of using bronze rod drifts. Unlapped sides mean you can’t align the grain with the sheer…you have to edgejoin straight boards…and I reinforced the resulting short grain in the bow and stern areas with dowels so they wouldn’t crack easily in collisions. Ramin (the straw-colored, big-box store dowels that have an open grain similar to mahogany) isn’t a durable wood and I expected they would be mush by now. But they held up perfectly, probably because they were set in epoxy and perhaps absorbed some of the acid in the cedar faying surfaces. I still recommend silicon bronze or marine brass rod or boat work instead of store-bought dowels, but it’s good to know you can squeak by with a shortcut now and then when you run out of something…thanks to epoxy.
    Sawn Knees.
    A common design, especially for utility skiffs, but a poor one. Too much end grain to sop up moisture compared to the face grain of laminated knees (top) or knees taken from grown crooks. Plus the end grain is an extremely poor surface for screw holding; long, copper rivets are a better approach. Treat all that end grain with CPES or thinned epoxy, and use bedding compound for both the knee faying surfaces and the fasteners:
    In these sawn quarter knees in the stern, I used my worst fir, treated the faying surfaces with thinned copper bottom paint, bedded the frame head poorly in bedding compound, and failed to bed the end grain and the fasteners entirely. The result was all that unsealed end grain wicked up available moisture, the topcoat of sealant and paint held it there until both stern quarter knees rotted and their fasteners rusted, as did one thwart knee…in spite of the old-growth fir it came from. Fortunately I caught these before they took too much of the transom with them. The bow knees didn’t rot because they rode higher out of the water when the boat was swamped, and remained drier. All the rot occurred in the areas immediately above the typical waterline, where necessary oxygen combined with the necessary 20% moisture content to grow mold and fungus in the wood.
    Knee Replacement.
    Having good patterns makes for fast and efficient work. I lay the three rotten knees out on a scrap of second-growth, vertical-grain Doug Fir 2X12…make the longest beveled cuts on the compound miter saw to separate the three blanks…
    … screw each knee to its’ blank so as to use a stiff hand saw to make the smaller bevel cuts, using the old knee itself as the index.
    Continued…
  3. Bob Smalser
    This is a much faster technique than transferring each fussy angle using bevel gages and pencil marks to a power saw, which won’t easily do those short, frame-head relief cuts anyway.
    Sheer Guard Replacement.
    Again, using the old guard as a pattern, the contractor’s saw is set up to mill a couple of VG Doug Fir 2X4’s to get out new, 5/4 guards…
    …followed by the simple tasks of ripping to width, resawing to thickness, and making the three bevel cuts; with cleanup and edges quickly eased using hand planes. The v-groove will hold the new rope bumper and was used because it will hold a thicker layer of bedding compound to seal the screws mounting the rope than duplicating the original cove would have. Like the smooth, unlapped sides, the bottom edge of the guard is sharply beveled so as not to hang up on things when the boat bobs in a swell.
    Preparation.
    Before installing the new parts, the boat is power-washed with Tri Sodium Phosphate detergent, belt and rotary sanded using coarse 50-grit so that all paint surfaces are clean, well-scuffed, and all chip edges feathered and corners eased to hold paint. The boat is then vacuumed, and as much of the old joint goop chiseled and pulled out of the seams as possible. Then the joints like these frame heels and other exposed faying surfaces…especially those involving end grain…are treated with CPES or thinned epoxy, which wicks nicely into the joint seams without acting as a glue to complicate repairs in the future. Exceptions to epoxy treatment are the cotton-caulked planking seams, which get only lead primer and seam compound so the cotton will remain flexible and act as a gasket instead of a hard wedge.
    Reparable wood damage is fixed using CPES followed by thickened epoxy, then faired…
    …and the new parts are installed, here using a thinned red lead substitute (it uses yellow lead chromate instead of red lead tetroxide) on the faying surfaces, as well as for a general primer. Vulkem 116 poly sealant is used on all faying surfaces after priming, and also in all screw holes.
    Continued…
  4. Bob Smalser
    New and old parts are blended and faired using block plane and rasp, reprimed as necessary, and every seam, check and void is filled with sealant and struck off before final painting.
    Using a farm jack as a third hand to accurately spring the guards into place for fastening. All parts that require bending into place benefit from at least a couple feet of extra length for leverage, whether you are steaming them or not. As the jack raises the guard into alignment with the sheer, the multiple C-clamps lock it into place before drilling pilot holes and fastening. Once fastened and while the clamps are still in place, the original copper framehead-to-side-and-inwale rivets are tightened up as necessary using a small, ball-peen hammer.
    Red Lead Substitutes.
    Not having a source for red lead a decade ago, I used 50-50 thinned copper bottom paint (the cheapest Fisheries Supply carried at the time) to treat the faying surfaces and cotton caulking of this boat in place of red lead. (It dries much faster than the copper napthenates like Cuprinol.) You can see the light green under the dings. It worked well. Now, after an evolution of making my own red lead, I’ve switched to Tukwila, Washington’s Far West Paints who make a “red lead substitute” using lead chromate. The stuff is yellow instead of red, but I’ve used it before on metal surfaces where it’s considered an excellent primer, and am confident it will work just as well on wood. It dries faster that my home-brewed red lead…within hours…and it causes the alkyd top coat dry much faster that it would without the primer. The topcoat will be a Kelly-Moore alkyd enamel for full compatibility with the primer, one of the last alkyds made as more and more manufacturers discontinue traditional, oil-based paints in favor of latex. Both paints run around 40 dollars a gallon.
    Hardware Store Sealants.
    The common, gun-grade caulks used as bedding and seam compounds all worked fairly well. Unlike traditional linseed oil and chalk compounds, none attracted mold and all remained perfectly flexible after a decade in the weather. The cheapest acrylic door and window sealants (top) were the most adverse to water and pulled out the easiest, although none fell out in service as they were well-covered by paint. The butyl rubber (bottom) was more tenacious, and the most tenacious is the polyurethane plumber’s caulk (currently on the boat), which is rated for continuous water submersion and is the most compatible of the three with oil-based paints. All are easily reefed from wet planking seams when the time comes…the acrylic too easily.
    If you use a plumber’s poly sealant like Vulkem as a bedding compound, be aware that it is slightly adhesive. Use paste wax on your metal parts as a release agent and prime and even paint wood parts where appropriate for easy disassembly when the time comes.
    Cotton Caulking.
    I checked the cotton in a few places and found it to be in fine condition, even though these side to plank-end seams didn’t get enough copper bottom paint for saturation. There is no substitute for getting the seam horizontal where you can dribble paint into the seams via gravity. I originally caulked these seams in the vertical, and should have used a piece of tin as a dam to wick in paint more thoroughly.
    Bottom Stringers.
    The fir bottom stringers or runners are worn and gouged in places to half their original thickness, and I really should replace them. But in seasoned Douglas Fir that’s a difficult, kerfed bend in the steambox, and I elect to repair them in place using epoxy worked into the cracks and thinned using a heat gun, followed by more epoxy thickened with cabosil to fill the collision damage, with care taken not to glue them to the cross planks. Overall, the stringers did an excellent job of protecting the softer planks. The remaining carvel seam caulking is also lightly tightened.
    Continued…
  5. Bob Smalser
    Bilge Pumps
    I originally mounted a small Rule plastic pump in a basket and kept a 12V battery in the dock box to pump the rainwater out before use; a really poor idea. It took over an hour to pump the boat out when full, the tiny pump routinely clogged with
    tree litter from the surrounding forest, and carrying the battery back and forth to a charger was a pain. I’ve since changed the heavy battery out for a lighter, 2-stroke, 1” dewatering pump that empties a boat in 10 minutes, and will permanently mount a salvaged bronze Allied Marine bilge pump I rebuilt for when there isn’t enough rainwater to bother with the gasoline pump, which is made by Koshin of Japan and uses a high-quality Mitsubishi engine.
    Finishing Details
    Naturally it rains in the middle of my last coat of paint, when the weatherman said it would hold off until midnight. But as a timberland guy in forest fire country, I’ll take all the rain I can get in July and August.
    But as someone who burns a lot of wet slash, I have some tools useful for drying large objects you may not.
    Galvanized carriage bolts applied below the waterline…like these mounting the bilge pump…get a coating of sealant to protect the zinc from the acidic cedar and also a wrap of cotton beneath the head to act as a watertight gasket. If this was a warm-water boat, I’d also apply some thickened red lead to the cotton. The bolt holes have been treated with CPES followed by red lead substitute primer.
    I elect again to use #6 stainless screws to mount the rope bumper, only this time with a lot of sealant and only a few screws. A helper to stretch the nylon rope and hold the stretched rope in place with clamps is useful before fastening. Phillips-head screws are easy to run in until the heads bury in the rope to hide them.
    Continued…
  6. thudpucker
    thudpucker Senior Member
    That's quite a story Bob.
    I liked the details you provided.
    I almost cringed when I saw that Claking tool.
    My 22' Cedar boat had to be Calked.
    My neighbor went down into his basement and came up with all five Calking tool's.
    He said: "Im giving these to you, as you'll give them to somebody else when your done with them. Like me, you wont ever want to see a set of these again!"
    I had to make a maul though.
    My little boat idea will be similar to yours. If my health will permit me one more try...
  7. BATAAN
    Likes: 101, Points: 0, Legacy Rep: 1151
    BATAAN Senior Member
    Bob
    Thanks so much for a boat's history. So many of us don't see vessels over a period of time like this and you have give a very nice article and series of pictures. I especially like your honest, simple, well-designed boat since it works for a living and is not a frivolity like most. Your explanation of the origin of swamp logs is great.
    Here's a decayed fir stem repair using yellow cedar and purpleheart on a 23 ton yawl built mostly of Port Orford cedar and fir. Trick was not taking any of the 1 3/4" cedar planking off in the process. Like you, I find hand tools are often faster and easier than power for some jobs. The PH outer stem weighed well over 100 lbs and was challenging to fit.
  8. Nurb
    Likes: 6, Points: 0, Legacy Rep: 82
    Nurb Junior Member
    Excellent thread Bob! I greatly enjoy the "time lapse" peak and great details. Thanks!
  9. Bob Smalser
    The salvaged bronze bilge pump ($30-50 on eBay) is mounted so the discharge spout can be rotated inboard, and the entire pump can be removed for cleaning and servicing without removing the mounts. The strainer-foot and lower end cap unscrew and the pump lifts out. Usually all these old pumps need are their plungers rebuilt with new leather to return them to full serviceability.
    Changes I’d Make.
    Gardner specified sides, bottom and transom of 7/8” pine, which I duplicated in local woods…but in hard use I’d prefer a bit more thickness in the transom, both for strength and looks. I’d go to 1 1/8” in Douglas Fir or Alaska Yellow Cedar and 1 ¼” in Western Red Cedar, using epoxy to reinforce the screw pilot holes in the softer red cedar.
    Gardner landed the sawn thwart knees on the inwale as well as the boat’s sides, and as a result there wasn’t room for two adults to sit side-by-side. I made them slightly smaller and landed them only on the sides, but if I build another I’ll laminate the knees in place, landing them on the frames. This would be a much stronger assembly with less end grain to seal and screw fastening into face rather than end grain.
    Last, I’d double plank the bottom, at least from the tuck to the stern. Unloaded at a mooring the rear planks ride clear of the water while their tops bake in the sun. Hence by the end of our dry summers they become weepers the moment the boat is loaded. They take up fast enough, but weepers can be disconcerting to passengers.
    The Grand Prize.
    Here’s one I need a bigger machine for. Three to four feet in diameter and almost a hundred feet long, laying so the skinny end rides out of the water and grows vegetation.
    And finally, this one is four to five feet in diameter and 120 feet long…somewhere around 50 tons of waterlogged cedar, waiting patiently for me to figure out how to retrieve it.
    Reference.
    John Gardner. Building Classic Small Craft. Camden Maine: International Marine Publishers. 1977. p12-15.
  10. troy2000
    troy2000 Senior Member
    You might consider splining the planks instead, unless you also have other reasons for double-planking.
    A very good thread. And of coure we're like young children around here anyway; we like anything with lots of pictures.:p
  11. Boston
    Boston Previous Member
    Pardon my noticing but I'm hearing allot about Douglass and fir decay in this thread, I'm kinda curious, what parts of the punt were built in Douglass that didn't rot within the ten year period of its use ? Not trying to start a fire storm of debate but it would be interesting to know.
    cheers
    B
  12. Bob Smalser
    I'm not a big fan of splining. More difficult to repair. Splines are weak unless you use quarter-inch plywood, which would turn to mush in these conditions. Further, for the manhours it takes to run all those edges thru a TS or slotting cutter, I can lay two layers of half-thickness planks and either caulk the outer layer or bed canvas in pine tar in between.
    Not to mention that caulking does a helluva lot more than keep out water...it strengthens the hull where splines to not.
  13. Bob Smalser
    The only rot was immediately above the average waterline where the member either had too much end grain involved or too many unbedded fasteners. The Douglas Fir chines, transom, frames, bow stiffener, front guard, rear bumpers, inwales, inner stringers, transom knees and seat risers emerged just fine from 10 years in the water.
    If I had bedded everything in this boat like I was raised and trained to do, there likely would not have been any rot at all.
  14. BATAAN
    Bob,
    Thanks so much for the progress and after pictures and the LOGS. Your practical little work boat is ready for another 10 years of labor and it sounds like you are too.
    Buck the logs in place? Handsaws work underwater....
  15. srimes
    Likes: 31, Points: 28, Legacy Rep: 214
    srimes Senior Member
    I bet a cordless electric saw would too, at least for a while. A compressed air saw powered by a co2 tank would be best. But it would still suck.
  1. bobbrown
  2. LandFish
  3. krashed
  4. Peter McKenzie
  5. Corley
  6. urisvan
  7. flyingvranch
  8. StormalongJohn
  9. Padmack
  10. SHoggard
