Asleep Helmsman
Senior Member
- Joined
- Jul 16, 2008
- Messages
- 241
- Reaction score
- Location
- Republic of Texas
I built some replacement doors for the companionway.
They're made out of teak and the styles and rails are going to be glued together. The pieces are coped to fit each other
There will be a panel of solid teak on each door, and a Plexiglas window.
So two issues:
If I glue the teak panel into a groove will it check (split) from expanding more across the grain? Or maybe I should varnish it first and let it float in the frame with maybe some silicone sealer around it?
If you have a better suggestion, I would appreciate it.
And the second is sealing the Plexiglas window. Silicone is always recommended for acrylic but if some gets on the teak it may make it difficult to varnish.
I thought about using some black rubber type material that doesn't cure hard and leave the paper on the Plexiglas except where it fits into the grove of the frame. Maybe even sand it rough in that area. After the black goop sealer cures it could be cut off around the window and then peal off the protective paper.
What do y'all think?
So two issues:
