I am actually working on a very small tacking / shunting Proa. 10' main hull, 8' beam, 30 lb main hull + cross beams + other structural members, 15 lb rig, light (but ??? lb) ama. If I can get it to work OK in displacement mode, foiling and/or hard wing would be the path to more performance.
For max speed (the objective) I will have the main hull, the rig, and the combination dagger board/rudders all to the windward. This is the "half a tri" concept.
However, if I need to work my way upwind without shunting, I should be able to tack.
I am intentionally not going to put any finishing touches on the initial craft and I am trying to maintain maximum flexibility for the configuration adjustments I expect to need.
The first round will be with a free standing rig that can take the heavy loads expected in the normal mode, and can take the lesser loads in the "ama to windward" mode.
Making it all work is just engineering. I plan to use mostly trial and error to figure stuff out rather that try to crunch numbers since I really need to get more "on the water time" anyhow.
