Symmetric Laminate with Double Bias Plys
Discussion in 'Fiberglass and Composite Boat Building' started by Johnfirstime, Feb 26, 2019.
  1. Johnfirstime
    Johnfirstime Junior Member
    This may seem like a stupid question but I'm looking at making a laminate that incorporates +45 and -45 degree plys.
    Since my part is significantly longer than the width of available fabric rolls, I will need to lay down the fabric parallel to the longitudinal axis of the part. However, I have only been able to find double bias fabric with the +45/-45 stacking sequence and not the -45/+45 stack. Therefore, even when flipping the fabric end over end, or rotating it 180 degrees, I am not able to achieve a symmetric laminate.
    How have others gotten around this problem? Should I just do a better job looking for fabrics?
    Thanks in advance!
    Likes: 2,235, Points: 123, Legacy Rep: 2031
    What is the symmetry that you want to achieve? I don't quite understand the problem. If the design requires the lay of the fibers to be absolutely different, you can always buy uni-directional cloth.
    Reefrunner likes this.
  3. Reefrunner
    Reefrunner Junior Member
    Very cryptive question. Need more of an explanation...
  4. gonzo
    If you want symmetry, that is the fibers on the outside of the laminate are parallel, uni-directional cloth can be oriented in any way. It takes more labor, but you will have complete control on fiber orientation.
  1. Blueknarr
  2. crossram
  3. hardguy007
  4. Paler
  5. leaky
  6. Steve W
  7. Runhammar
  8. Prettypicturegirl
  9. tbelliot
  10. RMA
