SY38 Teak deck removal, toerail problem
SwedenYachtsDaniel
Junior Member
Joined
May 23, 2018
Posts
20
Reaction score
Location
Norway
Hello.
Im removing the teakdeck on my SwedenYachts 38. And I will replace it Awlgrip nonskid ore something similar . The teak is removed from the cabin top, that was straight forward . But i have not started on the sides of the deck. The problem is that the teak goes under the toerail.
I have added a real life picture and 3 "drawings" .
Im considering two options:
1: leave about 5 cm of teak and then glass from the deck , over the teak and over the alu toerail. Then I won't have a problem with water standing in a joint on low spots trying to get in between hull, teak and toerail.
2: Remove the teak deck out to the toerail. and the just one layer of glass out to the edge . Easier way to do it. Maybe better ?
(red line in "drawings is the layer of glassfiber I will be adding)
Thankful for any advice ..
Back
