When designing a centerboard case for a swing down board, is there any benefit to having a square hard corner at the aft end of the case?
I'm considering a design change in the boat I'm building to soften rear end of the centerboard case rather than have it make a sharp corner. It seems as though that should make for much less turbulence. Am I missing something here?
This is a quicky drawing of what I was considering doing. The near side is my idea, as compared to the back side of a regular square case. It seems like this should considerably reduce drag, but I'm just not sure if it's worth effort to do or if I should try some sort of door mechanism to close behind.
Keep in mind this is a pleasure boat, NOT a racer, but I do want it to sail well and be reasonably quick.
