Swain BS_36 Stability curve
Discussion in 'Stability' started by junk2lee, Mar 9, 2011.
Thread Status:
Not open for further replies.
  1. tazmann
    Likes: 17, Points: 18, Legacy Rep: 215
    tazmann Senior Member
    This math is confusing
    Our 8" pipe 3/16" wall has 8.25" ID
    I came up with 6.8 Lbs per foot positive flotation if sealed.
    Tom
  2. Ad Hoc
    Likes: 2,003, Points: 113, Legacy Rep: 2488
    Tom
    Can't do imperial units..no idea how to use them.
    Dimensions given:
    Diameter of 165.1mm
    Area = pi*dia^2/4 = 3.14159*(165.1^2)/4 = 21408mm^2
    or 0.0214m^2
    If 13.6m long vol = 13.6 x 0.0214 = 0.291m^3
    SW = 1025 kg/m^3
    Therefore displacement/buoyancy in SW is 1025 x 0.291 = 299kg
  3. tazmann
    Ad Hoc
    When you calculate would you use OD or ID of the pipe to figure the flotation ?
    Tom
  4. abcdefg
    Likes: 3, Points: 0, Legacy Rep: 46
    abcdefg Junior Member
    Just two points here.....
    Mast self weight is (should*) be ignored at this point (in the context of the thread) since it should already be included within any displacement/vcg estimate or calc.
    Secondly, unless the mast itself can be shown to be watertight or buoyant to a pressure equivalent to a head of 13.6m seawater (mast height), then it should not be included in any buoyancy/rm calcs imo especially if claims of positive stability to near 180 are to be verified..
  5. Ad Hoc
    Eaxctly..that's why all the twists and turns from from BS is just that, BS, and should be ignored. Except for fun by pointing out the obvious errors in his mis-direction.
    Always OD...buoyancy is the volume of the immersed 'body'.
    Think this way. If you had a boat floating in the sea, then froze the sea. Take out the boat you're left with a "hole" or "groove" in the ice. This 'hole' is up to the hull plating (i.e. the OD). If you now fill the hole with water, and then pour that water onto a scales....it weighs the same as the boat.
  6. tazmann
    Thanks Ad Hoc
    My calcs on the 8" were ID Little off there
    Checked the 6" pipe 168 mm od 3/16" 4.77 mm wall and yep it only came out little over a pound a foot positive Not much .
    Tom
  7. MikeJohns
    Likes: 210, Points: 63, Legacy Rep: 2054
    MikeJohns Senior Member
    It's a mute point anyway.
    A knockdown resulting in an inversion is usually a violent event, few sailboats boats have managed to fully roll without losing their masts.
  8. pdwiley
    Likes: 90, Points: 48, Legacy Rep: 933
    pdwiley Senior Member
    I used light wall as this is more than strong enough - 3.5mm wall, 13.95kg/m according to my edcon steel catalog.
    As I thought - 4000lbs buoyancy is total crap. The mast would have to be made of that rare & unusual antigravitic unobtanium to give that sort of positive buoyancy.
    Tazmann, sorry, but I'm really not going to bother calculating anything expressed in antique units. I realise you live in one of the 2 last remaining backward countries but you have to come into the 21st century sooner or later, preferably well before the 22C.
    PDW
  9. TeddyDiver
    Likes: 150, Points: 73, Legacy Rep: 1650
    TeddyDiver Gollywobbler
    It was ftlbs.. so quite close. Thou stability would be better when dismasted :p
  10. bntii
    bntii Senior Member
    Is this true?
    Did I miss something when away from the forum?
    If so- Brent it is destructive to your case to use such falsehoods to present your ideals.
    You have long experience. Stand toe to the line and speak.
  11. tazmann
    I would rather settle for different than backwards ?
    Reguardless If I was going to build a mast from pipe I would
    need to go by what is available here.
    Tom
  12. Crag Cay
    Likes: 49, Points: 28, Legacy Rep: 607
    Crag Cay Senior Member
    This is not so; the whole of the boat should be considered.
    Evaluation of whether you can expect the deck house to remain watertight when inverted should be done when examining the structure of the boat as a whole.
    But most importantly, assuming the boat to have a flush deck wouldn't give you any meaningful insight into how the boat would behave if the deckhouse didn't remain watertight.
    If Dehler can use the deckhouse of the Moody 45 to give an AVS of 180 degrees, then we should extend this liberty to everyone.
  13. peter radclyffe
    Likes: 111, Points: 73, Legacy Rep: 680
    peter radclyffe Senior Member
    liberty or death
  14. pdwiley
    With regard to most things, the USA is a leader and an innovator. With regard to sticking to inch based measurements, it's backward. Sorry but that's how I and most other people see it.
    I agree that you've got no choice when it comes to buying materials however.
    If you're planning on taking your boat outside US waters I hope you've made provision for 220V 50Hz power because that's far more common.
    How are you going with the Roberts hull?
    PDW
  15. tazmann
    Yep I could see our system would be tough if you are use to metric same the other way too.
    The Roberts hull I modeled it but that was as far as I got with it, change of plans.
    Tom
    Thread Status:
