AndrewGilchrist
New Member
- Joined
- Feb 5, 2013
- Messages
- Reaction score
- Location
- NSW Australia
Rick W the prop in the pic you put up is not a surface piercing prop. It appears to have absolutley nothing in common with one.
Note: This feature may not be available in some browsers.
My guess: consider which way the water is being shed by the props.For what it is worth, in my reading on the tests, videos and commentary by the designers... the two propellers had rotated inward toward each other. The result was a marked reduction in projected thrust and efficiency, probably a disturbance with the water flow toward the stern at the hull's centerline.
The propellers were then switched so they turned outward, thus rotating away from each other. The improvement was dramatic and exceeded projections. Why this had such a positive result, I do not know and will leave it to others to explain.
