I was originally going to post this on a current thread but decided that the topic/question may be of interest to more people.
Surface drives are typically used in high speed high rpm craft
Large diameter, low rpm propellers are assumed to offer higher thrust and better efficiency and in most cases would require a deep keel for prop clearance.
Ignoring the obvious safety issues of a having a large prop breaking the surface of the water aft of the transom the question is this:
Is it feasible to put a large diameter slow turning propeller on a surface drive with the goal being high thrust at higher numerical fuel efficiencies?
Efficiency being defined as more miles per gallon/ nm per fuel unit
Just happened across this picture but do not have a clue of the application
