Super simple, stackable boats for floating festival
Discussion in 'Boat Design' started by geekeasy, Mar 23, 2012.
  1. geekeasy
    geekeasy New Member
    I'm looking at designing a craft for a floating festival. These boats would primarily be used to move between groups of houseboats and other boats.
    The design needs to meet the following criteria:
    1) People with little to no knowledge of construction can build it in less than a day (excluding painting)
    2) It can comfortably hold two people.
    3) The boats need to be stackable. For storage and transport, it's critical that these can stack such that they won't take up too much space.
    I was looking at this super-basic design for a one sheet boat:
    http://www.youtube.com/watch?v=XY2YuO_BD1c&feature=related
    I was considering adjusting it, doubling it to make a two sheet boat, and sloping the side edges out such that the boats would stack.
    Unfortunately, sloping any of the edges will make the build process quite a bit more complex for novice builders. But we may have to live with that.
    Does anyone have any feedback on this design? Does anyone have any other designs you'd suggest?
    Thanks!
  2. DCockey
    DCockey Senior Member
    How large will the heaviest pair of users be?
    Will the users all be experienced in small boats?
    Size constraints?
    Do they need to look like somebody's idea of a "boat"?
  3. nimblemotors
    Likes: 3, Points: 0, Legacy Rep: 4
    nimblemotors Senior Member
    http://www.rebelcat.com/
    no sail use paddles, how stackable is stackable?
    You can't beat inflatables for off-water storage.
    A couple air mattresses instead of PVC pipe, just rope them around the plywood sheet.
    pool noodle boats are quite cool.
    http://www.youtube.com/watch?v=jqIOeFRpuA4&feature=related
    Are you making the building of it part of the charm of the event?
    Can one get wet on it?
    How about some zip lines between boats? :)
  4. Jeremy Harris
    Likes: 59, Points: 28, Legacy Rep: 711
    Jeremy Harris Senior Member
    Dory's are stackable and dead simple to build. They look like a "proper" boat, too.
    Persuade a sponsor to get the ply parts CNC cut (not expensive) and then just stitch and glue the boats. This would make the build a doddle, easily less than a day, with little in the way of skill needed by the builders, just a bucket load of zip ties, some epoxy and some glass tape.
  5. geekeasy
    geekeasy New Member
    Dory may be the way to go
    Jeremy, thanks. A dory might be exactly what I'm looking for. The first photo on the wikipedia page shows a bunch of them stacked.
    http://en.wikipedia.org/wiki/Dory
    I'm looking through design plans now.
  6. Petros
    Petros Senior Member
    You might also consider a simple pram or scow design, less severe angles and simple to build.
  7. hoytedow
    Make enlarged mortar tubs. They are stackable and have all straight edges, nothing fancy but they float well.
  8. hoytedow
  9. Petros
  10. Submarine Tom
    Submarine Tom Previous Member
    Geekeasy,
    Any used little life boats kicking around your neck of the woods?
    -Tom
