Summer Kyle
Discussion in 'Powerboats' started by Marco1, Mar 14, 2014.
  1. Westfield 11
    Likes: 8, Points: 0, Legacy Rep: 95
    Westfield 11 Senior Member
    I believe that Summer Kyle was designed in the mid 1990's: not so long ago. Wide bodied boats with the need for more HP were relatively common in those times.
  2. CDBarry
    Likes: 30, Points: 28, Legacy Rep: 354
    CDBarry Senior Member
    What I was mentioning is what used to be called composite before FRP; wood shell planking over metal frames. Nowadays the metal frames would be CNC, thereby reducing the need for a special jig.
    There are a lot of different approaches, but the combination of materials can be very cost effective and structurally efficient.
    I did a presentation on this at the CPBS in 2012 - the videos are linked from the post on the 2012 CPBS.
    Repeating the link:
    http://www.tvworldwide.com/events/p...5/default.cfm?id=14775&type=flv&test=0&live=0
  3. Mr Efficiency
    Likes: 473, Points: 83, Legacy Rep: 702
    Ok, I follow, metal frames.
  4. Mr Efficiency
    Of course, but the hull design is far more in keeping with the vogue of a much earlier era.
  5. Marco1
    Likes: 28, Points: 0, Legacy Rep: 240
    Marco1 Senior Member
    The stile is from the 1930ties, the tunnel is developed from the Atkin boats, designed for a customer in 1996 me thinks, I don't follow with the "need for more HP". The suggested engine is 170 HP. One of the first built used a Cummins 6b instead of the yanmar 170 suggested and the owner states it was an overkill.
    More HP would do little good in this boat, even when a Cummis 6B over a Yanmar 4 is a bloody good decision. I would go for a JohnDeer 6068 if it fits anything more is a waste of fuel.
  6. Mr Efficiency
    Not saying it needs more hp, the point was that the boat could perform with lower power than more modern (wider) boats would require. Not a bad thing with today's fuel price.
  7. Marco1
    Gotcha!
  8. Mr Efficiency
    One thing that might be an issue is water slapping around in that aft tunnel feature, riding at anchor. Keeping people awake possibly. But a lot of boats have noise producing surfaces that are annoying. In the case of alloy, they all sound like a barrel with marbles rolling around !
  9. Marco1
    Mmm, you have a point ... perhaps one could stuff a bale of hay or an old pillow in there? :D
  10. Mr Efficiency
    Or build in GRP/PVC foam sandwich, which makes a quieter boat than most.
