I keep hearing the hype about a skinned core being xxx times stronger than solid lay up "of equal weight" - I completely understand this is due to the distancing of the skin laminates and partly due to the core itself.
It is my understanding that when you core you would use the same amount of glass with a core as you would in a solid lay up ---- just say for arguments sake.
cored ----- 3 layers glass - core - 1 layer glass
solid ------- 4 layers glass - no core
3/1 ratio on the glass with core compared to solid - this is the basis of the equal weight comparison, correct?
Ok - I see a potential for abuse here on boat design and building - seems to me they will (because it is stiffer) use less on the skins with the core to cut costs because it will be stiffer than the original solid layup. The original solid layup will have less puncture protection but will it be strong enough - that is the real question.
for arguments sake, my thinking - and I am speaking in regards to no real project here - If a layup schedule calls for 1 layer each:
Cored - csm / csm / triax csm / core / triax csm
if I dropped the core would it be strong enough according to their comparisons. I understand this is relative to to them skimping on the design in the first place.
As well - due to issues such as design considrations, complexity and cost of equipment and processes, cost of coring material itself, difficulty - is it really worth it to core the hull of a catamaran below the waterline especially with complex curves.
What if (above example) you did away with the core and added a few more layers of csm triax. (as long as its strong enough) Would it be worth it to have solid below the waterline vs the core? I just don't see where the added weight will really be that detrimental to the project. I understand it will not be as strong as the cored and quite frankly none will be puncture proof.
There seems to be alot of hype about coring hulls but no one wants to talk about solid glass hulls and cored topsides. I do understand we are not comparing a 3/4 inch cored to 3/4 inch solid - I think the solid would probably win.
All sounds like a lot of advertising hype to me when it comes to coring hulls. Is it really worth it - taking everything into consideration?????
