Strongplank vs. woodcore
Discussion in 'Fiberglass and Composite Boat Building' started by LAZYJACK, Feb 23, 2007.
  1. LAZYJACK
    LAZYJACK Junior Member
    I would like to get information on a material called Strongplank which is suggested as a replacement for wood (eg. red cedar) in a woodcore-type construction with epoxy. Advantages would be: lighter hull, slightly stiffer, better ballast/displacement ratio, no risk for delamination, no risk for rot in case of water infiltration. Has anyone experience with this material ? I am looking at construction of a hull (sailboat) of approx. 41 ft?
  2. Vega
    Likes: 26, Points: 58, Legacy Rep: 132
    Vega Senior Member
    Eversail yachts are built with that stuff. I was there and I liked what I saw. It makes sense to me. Its site has an explanation about the product. It used to be also in English, now it is only in Dutch. If you are Flemish you will understand, otherwise write to them and ask for a translated paper (they have it), or even better, pay them a visit. They are nice Guys.
    http://www.eversail.nl/index.php?menu_id=59
  3. LAZYJACK
    Thanks Vega. I've seen the Eversail site and will visit them next week at the Hiswa in Amsterdam. They seem to be the main user (promotor?) of this product. A few other yards are sited having build in Strongplank, but apparently none outside of the Netherlands.
    Keep info coming.
  4. Strong Plank
    Strong Plank Composites
    Experience with Strong Plank
    Yes endeed I do have some experience:
    My passt projects I supported
    28`Collin archer
    several 35`cruiser
    3 classik coasters
    3 Kaptn speed boats´
    1 High speed Tender above 65 knots full Carbon / with Strong Plank
    3 - 40`Saling Yards Nissen and JV Desing
    1 - 60´ Sailing JV desing (small Pinta)
    And the largest 160 ft Schooner
    For what Information your searching for?
    rgds Robert
  5. Raggi_Thor
    Do you have any cost and weight estimates?
  6. amg
    amg New Member
    I am also interested in that building process, did you find the initial company that does the stongplank, have you get any further information other then those given by the ship yard?
    Thank's
  7. Vega
    Vega Senior Member
  8. amg
    amg New Member
    No A am not, but i speek a little deutch... I hope I will understand everything... or I will ask a translation at a friend...
    Thanks
  9. lazeyjack
    lazeyjack Guest
    i wonder if you would consider changing your name, I have used this name since 2004, and I think your name being similar may confuse some?
    what do you think?
    regards lazeyjack the first
  10. Buckie
    Buckie Junior Member
    Looks interesting...I was thinking about doing the same type of thing but using veneers, glued and laminated to about 2" thick. can anyone see any problems with it ?
    buckie
