Strip planking thickness
Discussion in 'Class Societies' started by DUCRUY Jacques, Jan 22, 2011.
  1. DUCRUY Jacques
    DUCRUY Jacques Junior Member
    Hello,
    I find a formula in the ABS ORY rules for calculate the thickness of a carvel planking : is this formula valuable also for the traditionnal strip planking ?
    This formula is not very clear for me :
    t = 1.09 * (4.2 - (1.13 L^0.25)) * s * ((0.001 Fh/St)^0.50
    with St : admissible stress (for example for mahogany 8 * 0.4 = 3.2 Kg/mm²
    It seems to me that the result is a irrealist thickness (too much ?).
    Is my interpretation correct ?
    Thank you by advance
    Have a nice week end
    Jacques
  2. rwatson
    Likes: 495, Points: 83, Legacy Rep: 1749
    rwatson Senior Member
    Generally, the term "strip planking" is associated with fibreglass inner and outer cover.
    Without the fibreglass "skins", strip planking *is* Carvel planking
    Maybe you were referring to Clinker Built V Carvel Planking ?
    eg http://en.wikipedia.org/wiki/Carvel_(boat_building)
  3. Paul Kotzebue
    Paul Kotzebue Previous Member
    Strip planking refers to narrow planks with edges nailed and/or glued to each other. Carvel planking has caulked seams. Carvel scantlings should not be used for strip plank construction. ABS ORY design pressures can be used to derive strip plank scantlings using the same principles as cold molded construction, with the planking treated as a unidirectional material with no strength perpendicular to the direction of the grain. ISO 12215-5 has specific guidance for strip plank construction scantlings.
  4. DUCRUY Jacques
    Thank you very much.
    If my understanding is good, in ISO 12215-5, the admissible stress is :
    for cold molded : modulus of rupture * 0.30 * 0.5 (FOS)
    for strip : 1.6 * 0.07^0.5 * modulus of rupture * 0.5 (FOS)
    and the good formula for thickness :
    t = s ((0.5 Fh)/(1000 st))^0.5
    But the rule for strip planking is not very clear in ABS ORY !
