michael pierzga
Senior Member
- Joined
- Dec 18, 2008
- Messages
- 4,862
- Reaction score
- 116
- Location
- spain
Then go for it !!!
Keep up posted .
Keep up posted .
Note: This feature may not be available in some browsers.
Buy a Kevlar canoe and maybe dress it up and you will have not only money in the bank but time on your hands to visit the water while quite possibly no additional back strain too in many cases.
Buying is not fun. What can I do, I like projects, the more naysayers the better;-)
The pink board which is normally house insulation foam has little to no compression strength. Your glass bond to the pink board is marginal to questionable. Drop the canoe on a rock or attempt to go across uneven areas in the rivers and you will end up with a flawed hull without huge reinforcements in additional material by comparison to off the shelf canoes and internal components.
Reasons my friend, you must have a reason to do what ever you do. Why not is not a reason. There's no time saving, that's at vaste of time (except a good lesson)
Unless the edges of the strips are glued together. That's standard proceedure in modern woodstrip building.Whatever foam type you may use, when you cut strips or attempt to conform foam to a continuous changing shape and using strips to do so, you remove a lot of the structual intergrity of the foam as a mass sheet along each edge, even the most dense forms of it.
Oh I know very well about strip plank construction methods. In free standing and larger hulls, fasteners are also part of the edge grain gluing too both for pulling the pieces into alignment and to hold them while the glue dries.Unless the edges of the strips are glued together. That's standard proceedure in modern woodstrip building.
I think having a hobby is perfectly logic and rational.For many people "Because I want to" is sufficient reason. Their lives are not governed by a need in every aspect for perceived logic and rationality.
I know that so polystyrene foam wouldn't be my first choice. It works in surfboards though... <snip>
I was also thinking (optional) that I could glass both sides of the foam sheet and then cut the strips. I read about that method somewhere. Strips are glassed on both sides with glassed surface perpendicular to inner/outer skin. It supposed add rigidity to the construction.<snip>
The strips would be glued together
There is a material out there that is a form of a honeycomb configuation that transfers loads from one side of the structure to the other side, unlike strips of foam that gets glassed over even in a round shape. Yes, I was thinking about Nidacore but I didn't price their product yet
While you can heat quality sheet foam with a heat gun and conform it to a round surface mould and is done all the time improve your main structure before you glass both sides, a canoe shape is a compound shape, which will require you to reduce the physical running distance of the foam around the entire structure on each end which removes some of the intergrity to get big sheets to conform properly.
I have never tried that but I like the idea. It is like Farrier trimarans are build just on the smaller scale.
http://www.pwt.net.au/Feature Articles List/Build of the trimaran - KISS.pdf
It would require different mold but would be interesting to try...
I just feel like I want to build something. I like projects. Is that a reason?
