Stringers
Discussion in 'Boat Design' started by georgiahemi, Aug 24, 2012.
  1. georgiahemi
    georgiahemi Junior Member
    Hello all! I am working on an older 70's model 14 ft bass boat. I removed the floor, transom, and stringers already. I replaced the transom, now I am working on the stringers. I have the middle stinger already in, but now I am making the pieces that go from the center stringer, up to the sides. I am wondering if I should cut a small angle down where these pieces meet the stringer and hull for water drainage. I am going to fill all these cavities with foam, but I had heard that water will need a way out if it enters. Any suggestions? I have tried to upload a picture on here, hopefully it worked.
  2. georgiahemi
    Here is a better one.
  3. gonzo
    Likes: 1,457, Points: 123, Legacy Rep: 2031
    Drains (limber holes) are a good idea. If water never gets in, you lose nothing.
  4. PAR
    Weep or limber holes right next the centerline stringer, in the athwart supports, will permit water to drain aft to a transom hole. Any other fore and aft/athwart stiffeners/stringers that block water flow, should also have these holes. Typically the minimum size is 3/4", but bigger isn't a bad idea. Just picture water inside the boat and how it needs to flow aft to get at a transom drain and they become obvious.
