3d viewer and formats
Discussion in 'General Computing' started by yipster, Jan 1, 2007.
  1. yipster
    Likes: 98, Points: 58, Legacy Rep: 1148
    yipster designer
    what java or dhtml applet supports 3d exploring without installing a viewer first
    who likes acrobats $900 pdf 3d viewer (build into the new acrobat)
    looks like vrml is still the most versatile and universal after a decade deepfreeze
    what is the best 2007 (free) real time 3d viewer
    other ideas or considerations ?
  2. yipster
    yipster designer
    seems microsoft means with real 3d the tabs now in their new v7 explorer :rolleyes:
    its spyware and javascripts etc now need permission
    dont see the need for that new skin or can anyone enlighten me beter than ms?
    X3D seems to be the new VRML norm but looks to me more of the same
    really a pitty that real time 3d seems to be reserved
  3. Raggi_Thor
    I think more and more cad programs will be able to make 3D PDFs, and you can assume most people have the viewer already.
    One possible problem is that you give away too much info, the receiver may convert the 3D model to his own cad program and then modify it or use it in a way you didn't want.
  4. CGN
    Likes: 9, Points: 18, Legacy Rep: 138
    CGN Senior Member
    Yipster if you can find a copy of the past 3Dworld magazine i think is #86 there is a free copy of wirefusion demicron where you can import a vrml file and post it to the net for free is very good and for the cost of the magazine it really does the trick i just got myself a copy.
    Other way i have used is Viewpoint tools is a little bit tricky to use but IMO is one of the best the only problem is that they want you to pay to publish your work on the net, but for presentations is great.
    most o fthe problem i sto be able to reduce the size or compress the models including textures so is easy to load but some work and anyone shoudl be able to do this.
  5. yipster
    yipster designer
    most cad programs export VRML but to view real time 3d over the web you need a player, goes for all the other formats too
    acrobat PDF ($900) now has 3d and more but you have to open and view in a PDF viewer
    havent thought of giving away but i dont buy it that 15 years old VRML open source never got used nor was supported by the explorer
    it needs java applets in html to show real time over the net without viewer instals and now java pretty much gets blocked
    or do these two sites show 3d you can rotate with the mouse without (hidden) viewer instals?
    http://www.albatrossdesign.com/products/java_viewer/
    http://www.sygem.com/Jazz3D/Demos/prettyLoader.html
    hard for me to tell since i got dozens of viewers installed
    bout once a year i pick up a copy of 3Dworld mag, i look into wirefusion demicron, sounds like what i'm talking bout
    here some other viewers http://www.garybeene.com/3d/3d-pure.htm but to me VRML 97 is still standard
    if you like also see http://www.boatdesign.net/gallery/showphoto.php?photo=5394
  6. yipster
    yipster designer
  7. CGN
    CGN Senior Member
    is Free if you get and register the one from the CD (From the Magazine). Wirefusion Pro V4
    about the installs at least most of the ones i have seen they all need to install some are small some are more elaborated, there is no way to get around for now.
  8. CGN
    CGN Senior Member
    Yipster check Enliven pro if you are into 3D streaming this is one of the best tools.
  9. yipster
    yipster designer
    thats few hundred, better thana few thousend :rolleyes:
    downloaded the demicron wirefusion demo, didnt check if it imports reflextion maps and things like that but the partly working program works
    tommorow ill try to read the cover of 3d world if that really is a fully working wirifusion on the CD inside the 3dworld's plastic bag
    than again, i rather stick with free vrml or new x3d that also reads vrml, getting that streaming still needs an aplet tho
