Strange traveler car rivets
Discussion in 'Sailboats' started by Canracer, Feb 25, 2014.
  1. Canracer
    Canracer Senior Member
    Has anyone ever worked with this type of rivet? The end is peened, but there is a strange dimple.
    Should I take a drill to this, in order to remove the sheaves?
  2. jehardiman
    Likes: 1,452, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Semi-tubular, sometimes called a hollow base or Bray rivet, and yes you can drill it out. You will need to use a drill slightly smaller than the shank diameter then pry the rounded over head off.
    One of many suppliers
    http://www.orbitform.com/modules.php?name=Pages&sp_id=164
    Edit to add....looks like a Catalina 22 traveler car BTW.
  3. Canracer
    It's a Coronado15, and I think they used some bigger boat parts. What ever inventory they had, must have made it into the C15.
    I drilled them out. Now I have some odd sized sheaves to replace. Any suggestions?
    Need two: 1" OD, 3/8th" ID, and 3/8th" thick.
    Need two: 1" OD, 3/8th" ID, and 1" thick.
  4. jehardiman
  5. Stumble
    Stumble Senior Member
  6. Doug Lord
    Doug Lord Flight Ready
    Thanks for that Greg! Important find to me....
  7. Canracer
    Thanks everyone. I checked out that link for zephyrwerks. Right now I am bouncing between three sites; Harken, Ronstan, and Shaefer.
    Right now I've got sheave on the brain syndrome.
  8. Canracer
  9. Canracer
